e90...question about 275s...rubbing
10-10-2018, 01:25 PM | #1 |
16
Rep 151
so right now i am on sport suspension with 275/35/18 rears, wheels are 18x9.5 et 33( i think). With people in the car i rub on the passenger rear. (got the rear shocks/mounts replaced...better, still slightly rubbing with people in the car). also my rear passenger side sits slightly lower than rear driver side, it doesnt look significant, and ive heard this is normal. but the rubbing seems to be isolated to that side.
Is my tire just too tall? Possible i have a busted spring? I am about to do front struts and do lowering springs all around. Should i go for a shorter tire? wait and see if some fender rolling/alignment will help? trying to figure out my best course of action so i only have to fix this once! I appreciate any insight or help u can provide!! |
10-10-2018, 06:26 PM | #2 |
4276
Rep 9,209
I have same rim and tire size. No rubbing. Set camber at -2.0.
boostvibes16.00 |
10-14-2018, 08:08 PM | #3 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
^^^^ What he said!
I've ran 285s WITHOUT any fender roll on my lowered track car. Many factors such as camber, wheel offset, how tall the tire is and what's the sidewall profile, can affect whether you will have rubbing issues or not.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
boostvibes16.00 |
10-16-2018, 11:59 AM | #5 |
Clean is the new cool, keep it that way.
808
Rep 1,685
The main issue is that you are on soft ass stock suspension. But yes, lot's of factors. I am on 265/30-19 and had to roll my rears because it would rubs on bumps with passengers. I am lowered on Bilstein PSS coilovers and fairly low.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
feuer4275.50 |
10-16-2018, 06:40 PM | #6 |
453
Rep 2,973
SO LCI and Pre-LCI cars have different spacing from hub to fender lip.
The LCI cars have his closer to the fender. Given the same offset and tire an LCI sedan might rub. I have 19x9.5 ET33 in the rear on my car with 275/30's and not rubbing. I have added 5mm spacers to move the tire toward the fender and don't rub unless I have heavy people in the rear.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
10-17-2018, 05:41 AM | #7 |
16
Rep 151
nice, im going to go ahead and lower it and get it aligned properly...then go from there
__________________________________________________
e90 N54 DPs - 7" FMIC - CP W/ Turbosmart DVs - MHD stg 2+ |
10-17-2018, 09:17 AM | #8 |
808
Rep 1,685
"unless" being the key word. I don't rub under any condition with them rolled. Plus I just don't see a reason to run 275's personally, just get good tires.
