10-09-2018, 02:13 PM | #1 |
Rep 46
19" Runflats Bridgestone or Goodyear?
Hi All,
Tyres are needing replaced in next few months and I'm wanting to stick with Runflats, Currently have Bridgestone S001 fitted and was considering a change to the Eagle F1 ASY 2 but after some re search they seem prone to side wall issues? Bulges etc? Anyone able to offer some input to help?. If the goodyear are prone to sidewall issues this could be a deciding factor. Cheers |
10-09-2018, 02:40 PM | #3 |
39
Rep 147
I've just had 4 new Goodyear's fitted. Kwikfit had a deal on and the price wasn't too painful.
I needed them replaced as the last service highlighted bulges on both near side wheels but my suspicion was that both had been run under inflated for a long time by the previous owner. Had the new boots on for a week or so now and am very happy with the grip and ride. |
10-09-2018, 02:45 PM | #4 |
Rep 25
+1 for Goodyear although I only have them on rear as fronts are still original Crapstones - 41k and the buggers still have 5mm left!😭. Much quieter than Bridgestones and cheaper too!
10-10-2018, 12:57 AM | #10 |
301
Rep 822
As above GY best, couldn’t believe the difference when I swapped. The only exception is wear rates where I think the BS’s are king! Probably why they are beaten in all other areas...!!
10-10-2018, 01:27 AM | #11 |
2814
Rep 4,936
Drives: 340i MPPSK
+1 for Goodyears.
Life is a state of mind |
10-10-2018, 02:22 AM | #12 |
Rep 46
Thanks guys. To the above who have used the goodyears for a period of time? No side wall issues? How long have yous had them on the car? When I searched on here quite a few had mentioned it was a big weakness for them? Just don't wanna end up with a great tyre that is prone to issues and needing replaced. I wouldn't be as bothered if they where cheap.
10-10-2018, 02:52 AM | #13 |
2814
Rep 4,936
Drives: 340i MPPSK
Been using Goodyears since late 2015 (Bridgestones before that) and in that time yes I have replaced one tyre because of a sidewall bulge. However, there was the tell-tale black rubber mark on the rim right next to where the bulge was which meant it was almost certainly a pothole attack. Prior to that I replaced a Bridgestone because of a sidewall bulge, so I wouldn't say the GYs are any better or worse.
10-10-2018, 02:53 AM | #14 | |
371
Rep 2,029
The GY's offer the best level of grip, comfort and noise reduction. Maybe you can buy through a well established tyre garage with the option of tyre insurance?
BMW fanatic having owned many, I've now gone B58 mad!
10-10-2018, 06:23 AM | #15 |
Rep 46
The only downside for me getting the goodyears is the sidewall bulge issues they seem to suffer. Maybe some more research is needed first to see if its still an issue now with them.
10-10-2018, 07:51 AM | #16 |
680
Rep 2,445
Drives: 2018 630iGT sport
Agreed the Goodyear are way better - although that said, I too had sidewall failure on one of mine on the front of the 435 after probably hitting a pothole (say probably, as I honestly don't recall hitting anything that hard, enough to make you suspect the tyre would be buggered as a result). That was at around 2 years/10k miles, so nowhere near being worn out.
10-10-2018, 03:00 PM | #17 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Another for Goodyears
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
10-11-2018, 08:31 AM | #18 |
86
Rep 149
I've been using run flats GY on our 1 series for over 2 years. No bulges, 24k miles covered in that time.
In my 4 series, I have original Bridgestones which I find quite noisy and once they wear off I'd like to replace it with something else. |
10-14-2018, 02:16 PM | #19 |
244
Rep 2,811
Drives: Jaguar XE P250 HSE
I can compare 19" Bridgestones against 18" Goodyear runflats. I managed to get 21,000 miles out of the Bridgestones but the Good years are at 29,000 miles with still 4mm of tread left. I've had no side wall wear problems with the GY as I had with the Bridgestones and I have replaced one tyre due to side wall bulge (must have been a pothole but I don't remember any bad ones at the time). They are quieter than the Bridgestones (mind you the profiles on the GY are 40 and 45 in comparison with 30 and 35)
When I do need new tyres, it will be the same again. |
10-14-2018, 02:38 PM | #20 |
6431
Rep 8,504
Why fit RFTs ? They're more prone to sidewall damage, more prone to shoulder wear (especially on the rears if they're staggered), can be noisy, and generally don't perform as well.
In the past 7 years and 2 BMWs (E91 and F31) I've had one sidewall bulge and one puncture - both in RFTs. Just have Tyreweld or a Slime Kit in the car in case of a puncture. BTW, the Bridgestone RFTs are truly awful. I'll never have them on a car again.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
10-15-2018, 02:26 AM | #21 |
261
Rep 548
My last 320d which covered 60k in 2 years, with Goodyear runflats … had 6 tyres replaced, only partially worn, but with bulges. I've inherited Bridgestones on a new set of 704's which I bought. I've so far covered 15k on & had no issues.
It's very difficult to decide really, the Goodyear's were quieter & a bit more compliant, but I already have a set of Michelin's non run flats ready to replace the Bridgestones … their tough to wear out though !!!
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
10-15-2018, 03:02 AM | #22 | |
157
Rep 429
For my car, Bridgestone RFTs are expensive ~£200 a corner. You can get Goodyears for £600 a set. If you go the non run flat route, Michelin tyres are again near £800 a set. Also, Goodyear RFTs are quieter and more fuel efficient than non RFT if the sticker is to be believed. Guess it's when you see £600 vs £800 people wince. |
