Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 dme corroded?
      10-07-2018, 07:47 PM   #1
hcopeland
14
Drives: Graphite E92 335i
N54 dme corroded?
I have a customer coming to me with a host of problems. He has a misfire in cylinder 6 and has checked all the injectors, coils and spark plugs. So I'm stuck between a bent valve and a shorted DME. Here's a picture of the small plug on the DME. There's some sort of corrosion or something that got in there. Does anyone have a pinout map for the DME?
'07 335i e92 -- RB Turbos - JB4 G5 - MHD Tune - VRSF Catless DP - VRSF Relocated Inlets - Devilsown/BMS Methanol Injection
      10-08-2018, 05:34 PM   #2
Groganrocket
380
Drives: 2010 e90 335i and 2015m4
Looks like moisture got into it.
      10-08-2018, 05:59 PM   #3
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
The good news, the engine is running. That means the processors and ram is still functioning. You can pull the ISN from this DME and set up a clone.
You may even be able to clean up the pins and have a good working DME, but I would still replace it anyways.
And yes figure out how water got to this plug.
Did the owner have a JB4 installed?
      10-08-2018, 07:10 PM   #4
hcopeland
14
Yes he has a JB4 on it. He's also on MMP turbos, Relocated inlets and bolt ons. I'm doing a compression test because the owner feels like it might be his motor but I'll know for sure after this.
