Boost Leak
10-05-2018, 07:23 PM | #1 |
36
Rep 307
Boost Leak
Really hoping someone can help me with this boost leak. I am FBO on MHD Stage 2+ acn 91. Have a 7" FMIC, VRSF CP, TiAL BOV(yellow spring), new boost solenoids, new vacuum lines, and tightened actuator rod. I've posted on the MHD one but haven't gotten a response and hoping I can fix my car so I can enjoy driving it again. Anything helps. I also have capped the plastic nipple on the IM and have a barb fitting that goes to my BOV.
https://datazap.me/u/edris335i/boost...=0&data=3-5-22 |
10-06-2018, 04:12 PM | #2 | |
36
Rep 307
10-07-2018, 04:23 AM | #3 | |
36
Rep 307
10-07-2018, 03:23 PM | #5 |
36
Rep 307
10-07-2018, 06:15 PM | #6 | |
36
Rep 307
Log before this one: https://datazap.me/u/edris335i/boost...a=3-5-21-22-23 |
10-08-2018, 03:32 AM | #7 |
36
Rep 307
10-08-2018, 03:58 PM | #8 | |
1903
Rep 6,968
10-08-2018, 04:53 PM | #9 | ||
36
Rep 307
10-09-2018, 06:42 AM | #10 | |||
1903
Rep 6,968
10-09-2018, 02:08 PM | #11 | ||||
36
Rep 307
10-09-2018, 05:02 PM | #12 | |||||
1903
Rep 6,968
check to ensure the oem inlet is fully seated on the turbo(s); it's rather flimsy to be honest. Any after mkt, silicone connection with a banjo, bolt based clamp is way better. Check the gasket on the sensor located on the rear inlet. Replace the vacuum hoses with platinum cured ones. Check to make sure your vacuum Solenoids are functioning properly. Change out the PCV valve & cap to an RB. Fix the wastegate rattle on your turbos by turning the wastegate screw 2.5x on the rear turbo & using the horseshoe, washer method on the front turbo. |
Edris335i35.50 |
10-09-2018, 08:29 PM | #13 | |
36
Rep 307
Also, my VRSF chargepipe has some play and feels like it could be loose. Not sure if it's supposed to be like that. If I need to, I can get a new c-clip from BMS tomorrow as well. It did not pop off when I tugged on it though. Let me know if I need to or if it should be fine. |
10-11-2018, 05:35 AM | #14 | ||
1903
Rep 6,968
No oil leaks in the VG? That can be a source if it's big enough. I am assuming you don't. Just double check all the vacuum line connections maybe... Connection from lower to upper charge pipe ? |
