Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions 2019 BMW 3 Series (G20) Official Specs, Wallpapers, Videos, Photos, Info!
      09-30-2018, 04:33 PM   #1
BIMMERPOST / Official Coverage
BMW 3 SeriesG20
330i / 330i xDrive
  • On sale March 2019
  • 2019 330i starts at $40,200 + $995 Destination in U.S.
  • 2019 330i xDrive starts at $42,250 + $995 Destination in U.S.
  • new 2.0-liter, inline 4-cylinder
  • 255 hp from 5,000 - 6,500 rpm (7 hp increase over F30)
  • 295 lb-ft from 1,550 - 4,400 rpm (37 lb-ft increase over F30)
  • 0-60 mph in 5.6 seconds
M340i xDrive M Performance
  • M340i and M340i xDrive models will be available
  • On sale Spring 2019
  • Inline 6 Cylinder Turbo
  • 382 hp / 369 lb-ft.
  • 0–60 mph in 4.2 seconds
  • More specific info here.
330e
  • 111bhp electric motor
  • 181bhp two-liter inline four-cylinder gas engine
  • High-voltage lithium-ion battery
  • System output: 185 kW/252 hp
  • XtraBoost: temporarily + 30 kW/41 hp to 215 kW
  • 0-100kmh: 6.0 seconds
  • Emissions: from 39g CO2 per km
  • Electric-only range: up to 60km (37 miles)
  • Market launch: Summer 2019
Exterior / Interior
  • 2.9 inches longer than F30
  • 0.6 inches wider than F30
  • 0.5 inches taller than F30
  • 1.6 inch longer wheelbase than F30
  • 1.7 inches wider front track than F30
  • 0.8 inches wider rear track than F30
  • Trunk capacity: 17.0 cubic feet (1.2 cu ft more than F30)
  • Hofmeister kink now integrated into the C-pillar, giving the rear doors “freestanding” glass edge
  • New colors: Portimao Blue metallic and Vermont Bronze metallic
  • New optional Vernasca leather upholstery in five colors with decorative quilting and seam patterns
  • Sport Line (Standard)
    • High-gloss Shadow Line trim for window surrounds, kidney grille bars and trim elements for the air intakes and rear apron. Interior trim strips in high-gloss black and sports seats for the driver and front passenger
  • Luxury Line
    • Chrome kidney grille, front air intakes and rear apron. Vernasca leather interior trim, Sensatec instrument panel and door trim, and fine wood interior trim strips in high-gloss Ash grey brown
  • M Sport
    • Variable Sport Steering
    • Standard M Sport Suspension or optional Adaptive M Suspensions
    • M Sport front bumper, side skirts and rear bumper. High-gloss Shadow Line kidney grille bars, air intake trim and rear diffuser in Dark Shadow. Sorts seats with M-specific upholstery, M leather steering wheel, anthracite-colored BMW Individual headliner and interior trim strips in Aluminum Tetragon
Chassis / Suspension / Aero
  • Body-in-white lighter by 44 lbs.
  • Body structure lighter by 16.5 lbs.
  • Aluminum hood and front fenders saves another 33 lbs.
  • Overall body rigidity up 25%; as much as 50% in certain areas
  • Suspension spring rates increased by 20 percent without loss of comfort
  • Lift-related dampers use for first time in a BMW model (featured on both regular and M Performance suspension)
    • Reduces body movement perceptibly smoothing out vibrations caused by bumpy road surfaces and dynamic cornering. The system adds extra hydraulic damping at the front axle and a compression limiting system at the rear. It is continuously variable and adjusts the damper firmness progressively according to the changing spring travel. This prevents excessive body dive when driving over large bumps and so avoids uncomfortable, nervous damping response.
  • Ride comfort and acoustics both improved
  • Aluminum swivel bearings and control arms for the front axle, aluminum wheel mounts and a new generation of wheel bearings for the rear axle significantly reduce unsprung mass
  • Front spring struts and engine sub-frame now made of aluminum
  • Drag coefficient (Cd) of 0.26, a reduction of .03 Cd over F30 3 Series
  • Active air flap control extends across the BMW kidney grille and lower air intake
  • Both the sportiest and most comfortable suspension available
  • Now with new valves and optimized control algorithm, which now also enables load-dependent control of the damping forces
  • ADAPTIVE mode is now available and adjusts car's responses to the driving style and, depending on the equipment specified, to the route profile. The control system responds to accelerator and steering inputs and the position of the selector lever to make the powertrain and suspension characteristics sportier or more comfort-oriented. The map data supplied by the optional Navigation system Professional is also used to prepare the car for an upcoming junction or bend.
Steering
  • Servotronic speed-sensitive power assistance is standard
  • Variable sport steering is part of the M Sport suspension and Adaptive M Sport suspension
M Sport Brakes
  • Four piston fixed calipers at the front
  • Single-piston floating calipers at the rear
M Sport Brakes
M Sport Differential
  • Option for the BMW 330i in combination with M Sport suspension or Adaptive M suspension
  • Electronically controlled, fully variable locking
Transmission
  • 8-speed Steptronic transmission as standard
  • Wider gear spread (from 7.8 to 8.2)
  • New control unit and further enhanced gearshift dynamics.
  • Shorter gearing for the lower ratios
  • Even quicker shift times
  • Launch Control function
  • Shift paddles
  • Automatically adapts its shift strategy according to the route and driving situation (i.e. uses data from the navigation system and from Active Cruise Control system’s radar sensor), thereby avoiding unnecessary gear changes when negotiating a series of fast corners and, when approaching a vehicle ahead, for example, to shift down early in order to use the engine braking to scrub off speed
  • Improved Auto Start Stop and Coasting functions
  • xDrive splits drive torque between the front and rear wheels more efficiently and can direct all torque to rear wheels
  • xDrive system weight has been reduced and its oil supply system optimized
Lighting
  • Full-LED headlights are standard
  • Optional LED headlights with extended features and U-shaped daytime driving lights
  • Optional Adaptive LED headlights with BMW Laserlight with their hexagonal DRL rings and blue, L-shaped elements
  • High Beam Assistant option available with Optional LED headlights and Optional Adaptive LED headlights
  • Optional ambient lighting with lighting of lines running along the instrument panel and door paneling. Six light colors and eleven combinations of brightness, light distribution and color scheme for all light sources in the interior can be selected from the iDrive menu. Dynamic interior light function emits pulsating light signals in specific situations
Comfort Access
  • Car will automatically unlock when the radio remote control is detected in its immediate vicinity and lock again when it moves out of range
  • Hands-free opening and closing of the trunk lid
  • New movement sensor in key monitors if key is being carried (and therefore is always transmitting) or has been put down on a table, for example, allowing it to switch into standby mode with the transmit function deactivated
Audio
  • Standard audio with ten speakers and 205 watts
  • Optional Harman Kardon (offered as part of the optional Entertainment package) with 16 speakers and and 464 watts
Driver Assistance Systems
  • Standard Collision and Pedestrian Warning with City Braking function
  • Optional Cruise Control with braking function
  • Optional Active Cruise Control system with Stop & Go function
  • Optional Driving Assistant system (includes Lane Departure Warning, Lane Change Warning, Rear Collision Prevention and Cross-Traffic Alert)
  • Optional Driving Assistant Professional
    • includes all features of Driving Assistant and the Active Cruise Control with Stop & Go function
    • Steering and Lane Keeping Assistant
    • Evasion Aid
    • Priority warning and Wrong-way warning systems
    • Cross-Traffic Alert
  • Optional Park Distance Control (PDC)
  • OptionalParking Assistant Plus with Back-Up Assistant
    • Automatically selects parallel or perpendicular spaces and maneuvers into them by taking care of steering, accelerating, braking and automatic transmission shifting
    • Automatically maneuvers out of parallel parking spaces
    • Park View, Panorama View and 3D Top View used to create a 360° image of the vehicle and its surroundings
    • Remote 3D View gives drivers ability to call up a three-dimensional live image of their vehicle and its immediate vicinity on their smartphone
    • Back-Up Assistant helps the driver to exit parking spots or maneuver when space is limited
Head-Up Display
  • Optional Head-Up Display
  • Projection area 70% larger than F30 3 Series
  • Enhanced graphics and additional display readings
  • Information includes car’s speed, speed limits and overtaking restrictions, Check Control messages, status indicators and warnings from the assistance systems, detailed route guidance and turn instructions, and telephone and entertainment lists
  • Also displays distance warning as part of the Active Cruise Control system
BMW Intelligent Personal Assistant
  • Intelligent, digital character that responds to the prompt “Hey BMW”
  • Range of functions and skills available will be constantly expanded as part of regular updates
  • Learns routines, habits, preferences and applies them in the appropriate context – e.g. for the seat heating or the places they drive to frequently using the navigation system (“Take me home”). It is familiar with the vehicle’s functions and is able to operate them as required. Saying “Hey BMW, I’m cold” will prompt the BMW Intelligent Personal Assistant to adjust the temperature inside the car accordingly.
  • Intelligent learning: the assistant learns more about the driver with every command given, every question asked and every setting selected
  • Can explain how car functions work (e.g. "How does the High Beam Assistant work?"), provide current status information (e.g. "Is the oil level okay?") and help answer questions (e.g. "What warning messages do I have?").
  • Knows the driver’s favorite settings, and can even activate a combination of them to enhance well-being. For instance, “Hey BMW, I feel tired” triggers a vitality program that adjusts the lighting mood, music and temperature, among other things, in order to make the driver feel more awake.
BMW Digital Key
  • Near Field Communication (NFC) technology allows car to be locked and unlocked from a smartphone (without need for car key)
  • Holding smartphone up to the door handle opens the car
  • Placing phone in wireless charging or smartphone tray allows starting of engine
  • Digital Key can be shared with up to five other people
  • BMW Digital Key available for all NFC-capable Samsung Galaxy smartphones running Android 8.0 and above
BMW iDrive Display and Control
  • Standard BMW Live Cockpit features iDrive 6.0 with an 8.8-inch digital touchscreen Control Display and a 5.7- inch digital instrument color display
  • Optional BMW Live Cockpit Professional
    • 12.3-inch high-resolution digital instrument cluster display
    • 10.25-inch digital touch screen Control Display
    • Adaptive navigation system,
    • Hard drive- based multimedia system with 20 GB of memory, Touch Controller, two USB ports for data transfer, Apple CarPlay and WiFi interface
    • Enhanced BMW iDrive 7.0
Full Press Release
Full 2019 BMW 3 Series Press Release - PDF
Highlights
BMW 3 Series (G20) Highlights
Wallpapers
G20 3 Series M Sport
G20 3 Series Sport Line
G20 3 Series Luxury Line
G20 3 Series Interior
G20 M340i
G20 3 Series
G20 3 Series Engine
BMW 3 Series (G20) Headlights
BMW 3 Series (G20) Design Process
BMW G20 3 Series Live Look From Paris
3/g20/330e
Launch Film
Videos
Reviews
G20 3 Series Reviews Compilation
See M340i / M340i xDrive thread
M Performance Parts
M Performance Parts for the G20 3 Series
Visual Comparisons
Visual Comparison: F30 3 Series M Sport
Visual Comparison: Lexus IS
Visual Comparison: A4 S Line
Visual Comparison: C-Class
Tech Specs
Appreciate 7
Law6381.00
jmg18658.50
Aust350z244.50
Tuxedo1407.50
sbstnc0.00
      10-02-2018, 02:18 AM   #2
hans007
605
Drives: 2020 BMW M340i
white m sport pics...
I think a white m340i or 330i m-sport is my next car
Appreciate 4
Jason40719.00
///M TOWN16077.00
Vervain397.50
khailuan110.50
      10-02-2018, 02:19 AM   #3
beto_L.A.
beto_L.A.'s Avatar
343
Drives: 2020 G20 330i
Car looks great!!!
The blue 330i is my favorite.
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK).
Appreciate 2
      10-02-2018, 02:23 AM   #4
paliknight
fuck this field
paliknight's Avatar
2192
Drives: 18 F80 CS/18 F80 ZCP/19 M2C
Remote start was mentioned in the reveal but not listed in OP.
Remote start using smartphone.
Also, they claimed 55kgs lighter than predecessor.
BMW family... for now.
      10-02-2018, 02:23 AM   #5
Law
Global Moderator
Law's Avatar
6381
Drives: E90 M3 6MT
2011.5 BMW M3  [10.00]
2004 BMW M3  [10.00]
That blue is just incredible.
I'll save my reservations about the tail lights until I see them in person, but overall this is a very solid design and going to sell like hotcakes.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread
Appreciate 8
///M TOWN16077.00
Jason40719.00
duky1314.50
zamboni1127.50
Tuxedo1407.50
khailuan110.50
joca107.50
      10-02-2018, 02:24 AM   #6
///M TOWN
///M TOWN's Avatar
16077
Drives: M GmbH
2018 M2  [8.78]
I'll save my reservations about tail lights until I see them in person, but overall this is a very solid design and going to sell like hotcakes.
Agreed.
      10-02-2018, 02:26 AM   #7
DCG
REBEL
DCG's Avatar
782
Drives: BMW X4
Introducing the all-new 2019 BMW 3 Series Sport (G20)
      10-02-2018, 02:26 AM   #8
hans007
605
i'm surprised at 2.9" longer. Makes it almost as long as my A4.... which is kinda pushing it as far as size. at least its lighter. And 3582 for a RWD 330i... uh where did the 55kg savings go?
      10-02-2018, 02:27 AM   #9
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
1625kg kerb weight for a 2L? its getting hefty!
looks great otherwise
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      10-02-2018, 02:28 AM   #10
DeeKay
DeeKay's Avatar
Denmark
553
Drives: 2021 Tesla Model 3
Originally Posted by DCG View Post
Introducing the all-new 2019 BMW 3 Series (G20)
My god that standard front and rear bumper is hideous! Damn ! Normally I like the standard "limo look" but this is just way off!
| 2021 Tesla Model 3 |
Appreciate 5
DCG781.50
nozydog465.00
wdeerfield2745.00
swanson733.00
Diegs1422.00
      10-02-2018, 02:28 AM   #11
Mani59
BMW Miniature Collector!
13471
Drives: E38 735i SE Individual
That joined up kidney grill and both front and rear lights look hideous!
Not a nice looking car but will reserve judgement until I see it in person.
Appreciate 4
DCG781.50
Alx00710.50
zamboni1127.50
Diegs1422.00
      10-02-2018, 02:29 AM   #12
Wills2
Barge driver
Wills2's Avatar
Ukraine
8647
Drives: 730d
Not sure about it myself, too much front end and not enough rear end it seems to fall away to nothing like the C-class, the rear on the F30 was much more squared off and seemed to push the car forward in its stance, the new one is too rounded and draws your eye from the roof line to the ground don't like it.
730d/Z4C
      10-02-2018, 02:29 AM   #13
hans007
605
red one from twitter.
more pics of white m sport from twitter... really liking the m-sport
      10-02-2018, 02:33 AM   #14
atorrealba
No_Country
19
Drives: 2012 E92 M3
Wow I love the red color, but it's impossible to unsee the Lexus-ness from some angles
The white 3er G20 just looks ridiculously like a Lexus from the rear if you cover up the badge
Appreciate 3
E9T.two138.50
Blado24.00
      10-02-2018, 02:34 AM   #15
DCG
REBEL
DCG's Avatar
782
Drives: BMW X4
Introducing the all-new 2019 BMW 3 Series M Sport (G20)
Clearly the M Sport is the ONLY decent Exterior Design.
      10-02-2018, 02:37 AM   #16
Patrik
Finland
158
Drives: BMW
That non M-Sport will need some time to get used to. Looks weird at the moment. M sport looks great though, and so does the interior!
Appreciate 2
DCG781.50
Diegs1422.00
      10-02-2018, 02:38 AM   #17
Aspe
Germany
11
Drives: BMW F21
It's an absolutely shame that apparently Europe will only get the M340i xDrive and not rearwheel-drive option.
I absolutely love my F30 340i especially cause it does not force me to allwheel drive like Audi (S4) or Mercedes (C43).
Everything else about the G20 sounds astonishing. And if the 330i really does 0-100 in 5.6 that could be quite okay too.
Non M trim looks quite nice with Luxury Line. Sport Line in white really needs some getting used to.
      10-02-2018, 02:41 AM   #18
DG20
DG20's Avatar
967
Drives: M340i
Awesome ! Can't wait
Instagram: @dg_g20
      10-02-2018, 02:42 AM   #19
nozydog
Driver
nozydog's Avatar
465
Drives: 2020 X2 M35i
At a full 3 inches (76mm) longer than the outgoing car I’m afraid I may have to say bye bye to RWD and wait for the new 1er... this car has just got way too big now!!
Why do car makers absolutely insist on increasing the size of EVERY new model...???
This growth spurt makes no sense as the new 5 series only grew by an inch or so!!
Appreciate 6
BMWRX98.00
lab_rat394.50
dmboone254972.00
E9TOU231.50
bobert858.50
tuco44644.00
      10-02-2018, 02:42 AM   #20
DCG
REBEL
DCG's Avatar
782
Drives: BMW X4
Thumbs down G20 3 Series Sport - WEAK Exterior Design Elements
Regarding the Mineral White G20 3 Series Sport reviled on the stage...
WEAK Exterior Design Elements:
Front & Rear Bumpers
T-Shaped Air Intakes w/Fog Lights
Protruding Door Handles w/oval cut-outs
Butterfly Kidney Grill
Front wheel arch "sharp crease"
*Cant stand the closed Active Kidney Grille concept!!! Theses engines need air cooling at all times, don't want the vehicle to overheat ♨️ in New York stop and go traffic in when it fails!
Where is Chris Bangle when you need him?
The Sport Wheels are decent.
Appreciate 2
boostm3683.00
swanson733.00
      10-02-2018, 02:45 AM   #21
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9575
Drives: G82 M4 / G87 M2
Absolutely incredible! Great job BMW!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      10-02-2018, 02:46 AM   #22
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
This car is quite attractive.... Especially the white non-Msport...
As much as I love my F30, this G20 is making mine start to look old, but
After further analysis:
It has a rear from a Audi, a side profile from Mercedes, and the front from the Lexus and Infiniti.
g20
