RB Super EVO 17T w/ 335d tank and CPE CP
09-28-2018, 08:55 AM | #1 |
143
Rep 567
I bought these with hopes of running factory location inlets and not having to relocate my coolant tank. With the EVO outlet there is just no way to do so. They are brand new and have only been carefully test fit. I put the front turbo on with a couple of nuts and test fit the outlet to see if the coolant tank would clear. Unfortunately, it did not. No lines or anything were hooked up. I bought these from an individual that had his original 19T EVO’s upgraded to the new 17ts. The turbos shipped directly to me straight from RB. The remaining portion of the kit was shipped to me from the owner. I cleaned the used portion of the kit and purchased replacement parts from RB as needed. The only thing needed to make the kit 100% complete are a few hose clamps. These should be able to be sourced locally. Also, the original air filter and heat shield are not included. Single air filters are included. I can provide the K&N part number if you wish to switch to that. If you have any questions or need any addition pictures, feel free to let me know. I have been in the community a long time and have made lots of transactions. I am as upfront as possible with everything I sell. What is included and the condition: New this is around a $4600 package. RB Super EVO 17T turbos- New from RB (opened to look at and test fit)- Received 05/18 so I am sure RB would be happy to transfer the warranty. Given his failure rates from the last 2 years it is safe to say you will not need the warranty. RB EVO Inlets- New RB EVO Outlets- Front section new (original owner cut for IC, rear section and aluminum joiner used but in good condition) RB PCV hose- New RB Heat Shield- Used, good condition RB Solenoid Bracket- Used, good condition RB EVO rear coolant line- Aluminum fittings used good condition. Hose, heat sleeve and clamps new. RB High flow oil drains- Aluminum fittings used good condition. One was cleaned up with a wire brush but does not affect function nor can be seen once installed. Tubing, heat sleeve and clamps new Air filters- Used good condition. 335D Coolant tank- New CPE 335d charge pipe- New. Test fit, a few minor blemishes in the finish.
07 335 6MT
10-17-2018, 11:25 PM | #4 |
punisher
22
Rep 200
Do I understand correctly that you're selling because you don't want to have to relocate your coolant tank?
Thanks! Just want to understand so I know if that's a reason I wouldn't want them either... |
