Dealership flagging car and denying warranty coverage because of after-market speaker |
09-27-2018, 11:53 AM | #1 |
Rep 13
In another discussion, I described an intermittent speaker signal issue that is either the amp or wiring. The dealership shop foremen thinks its probably a short in the wiring somewhere if it's not a loose wire from the amp harness. Because the problem is not occurring right now they say it's hard to diagnose.
BUT they are flagging the car with BMW engineers. They say it's BMW policy to void warranties for any aftermarket parts including speakers. They made me put back in the factory speakers before they'd even look at the car. I informed them of the Moss act but they tell me I'll have to sue BMW to get the warranty coverage. This is Advantage BMW in Houston. Has anyone had this experience with BMW or dealerships? These are speakers made to work with the factory amp, plug and play, not even cutting a single wire, with the proper ohm loads. |
09-27-2018, 12:17 PM | #2 |
106
Rep 237
If the aftermarket speakers caused the short(somehow) then the Moss Act doesn't cover it and they don't have to cover it under warranty. However, they also have to prove that it was the aftermarket speaker or install problem.
And you don't necessarily have to sue them, but you can likely file a complaint with the FTC as they are the ones that enforce the Moss Act. You could also contact your state Attorney General. https://www.consumer.ftc.gov/article...ne-maintenance |
09-27-2018, 12:42 PM | #4 |
Rep 13
The part that is relevant to all members, is that they are claiming that BMW policy is to void warranty of all related components for any modifications, despite Moss act.
There is no way these speakers could do any damage to the amp and there is no way these speakers could cause a short in a wire someplace in the line. In fact, at the moment everything is working correctly, as the problem is intermittent. There is not way they could prove the speakers caused any damage. But they aren't even getting that far. They are refusing to do more than 30 minutes "complimentary diagnosis" without permission from BMW engineering. Thanks for the advice on contacting the FTC. The attorney general in Texas is unlikely to do much to protect consumers, but I'll look there too. These are just speakers, made to work with the factory amp, and the speakers could not be the cause of the problem. It's extreme for BMW to be taking this position knowing they are in violation of the Moss act. |
09-27-2018, 12:43 PM | #5 |
3279
Rep 3,256
I mean I sort of get it, even if I don't necessarily agree with it. From their perspective you are asking for warranty work on a system you modified with parts they aren't familiar with. Granted it's just a speaker but I sort of understand the position. Recommend you replace the stock speaker. It's one of those things that's easier to do and probably will save you time/trouble.
09-27-2018, 12:53 PM | #6 | |
1753
Rep 2,942
But that's neither here nor there, really. I have a feeling that your dealer simply wants to avoid a semi-expensive warranty claim (re-wiring) and is feeding you a bunch of imposing BS to achieve that. My advice? Go to another dealer. As another poster mentioned: Speakers cannot damage components connected to them; only those components can damage the speakers. An analog audio stream is one-way only, and speakers are completely passive components. Short (pun partially intended) of physically damaging the wiring during speaker installation, they cannot possibly, under current laws of physics, damage anything connected to them except one way: they operate at such a low ohm rating that the amplifier can't handle the electrical load and overheats. I seriously, seriously doubt the speakers you installed are creating that kind of issue. Advantage BMW has a questionable rep. I'd try either Momentum (also a questionable rep, but mainly regarding sales tactics) or BMW of Houston North (a relatively new dealer that might be more willing to work with you).
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 09-27-2018 at 12:59 PM.. |
09-27-2018, 01:30 PM | #7 |
Rep 13
The dealership gets paid by BMW to do warranty work. It's hard to understand why they'd try to push away warranty work.
I suspect this is a BMW push to see what they can get by with. They can probably deny warranty in violation of the Moss act 80% of the time and the average owner won't know about the Moss act or be a member of a forum to get help. So they make lots of money in denying warranty and back down just before a lawsuit or in response to FTC complaint. Could also be that the dealership charges a higher rate for non-warranty repair. Very upsetting. These are just speakers. And the law is very clear on this. Last edited by 2017M240i; 09-27-2018 at 01:42 PM.. |
09-27-2018, 02:27 PM | #8 | |
4517
Rep 8,942
I'm not defending what they're doing to you nor do I think it's fair, just trying to illuminate some of the multiple agendas you're dealing with.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
Viffermike1753.00 |
09-27-2018, 02:43 PM | #9 | |
1753
Rep 2,942
To repeat: Speakers can't cause damage to components in car audio. This is physics. 2-ohm drivers were used on some early 2 Series models, so we know from that info that the amp can handle a 2-ohm load. What you are being told is absolute, total, unequivocal BS ... ... and if a dealership is going so far as to flag your car's file for this? Never, ever, EVER give them a cent of business again -- and tell them that. In fact, tell BMW NA that, too.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
BM235iW97.00 |
09-27-2018, 03:12 PM | #10 |
Rep 13
Thanks for the help.
I was pulled into a meeting with three people from service and the service foremen agreed that there was no way for the speakers to damage the wiring or the amp. And yet they insisted that they'll lose their jobs if they repair the vehicle under warranty without permission from BMW. The fact that they have contacted the BMW engineers to get BMW to either approve or deny warranty coverage, means taking it to another dealership will be the same result, assuming any of this is true. The other dealerships are much further away from where I live and my attempted purchase experiences with Momentum were so bad I will never do business with them again if I can help it. I'd rather force them to do the warranty work. But I won't spend a penny of my own money now for service when the time comes Etc. There are good local mechanics in Houston. |
09-27-2018, 03:36 PM | #11 | |
4517
Rep 8,942
Me: my speaker is jacked up Dealer: the aftermarket ones? Me: yep Dealer: swap the stock ones back in. If the problem persists we know it's the car, if not we know it's the speaker. If it persists bring the car in with the original gear and we'll get it taken care of. Again same exact situation as you, not causing any trouble with corporate, and dealer still covers their ass. The key is finding someone intelligent enough to understand how to play the game. That said once a ship sails it's tough to bring it back to port, so you've gotta ride out the storm at this point.
2022 Macan S
09-27-2018, 06:33 PM | #12 |
Rep 13
They brought out another manager who verbally, not in writing, has backed down from their earlier position. He admitted that speakers can't damage the amp and said they would address issues as a warranty problem if the problem returns. But it was an effort to get him to say this directly.
They are blaming the signal issue on the sound generator being coded out. I'm doubtful that this is the cause. They claim they inspected the wiring at the amp and everything seems fine. |
09-28-2018, 09:59 AM | #13 |
447
Rep 1,268
Find another dealer. Get up to speed on the Moss Edmundson Act.
Ooops! Magnuson–Moss Warranty Act (P.L. 93-637). https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act Last edited by MarcoZandrini; 09-30-2018 at 02:36 PM.. |
Viffermike1753.00 |
10-08-2018, 04:08 PM | #15 |
83
Rep 216
Not that it matters much, but is this the downtown or clear lake location? I had some issues with the clear lake service department in years past, but the store overall took good care of me when the service department screwed things up. I'm about to buy another car from them (M2 Comp), but I'm taking delivery at the Performance Center in SC.
I do understand the stores first response, having run a shop for mobile audio/video install in years past (college days while getting a mechanical engineering degree). If someone modified our work, we no longer warrantied it, as it at times took way longer to diagnose and redo. That time has a cost, and without a clear indication of who's paying this cost, it's in the interest of the store to be conservative. Glad to hear they seem to be changing their tune though, and hope it works out in your favor! |
10-10-2018, 05:25 PM | #16 |
30
Rep 71
Anecdotally I’ve heard the M240is are having some issues with amplifiers. I had mine replaced on my 2017 dealer told me it was a $4k+ job. Prior to doing so they did puma testing because, as they told me, they’ve already seen 6 in the last 6 months. Not a huge dealership either. Just another data point for how it might not even be related to your aftermarket speakers
Viffermike1753.00 |
10-27-2018, 11:35 AM | #17 | |
5559
Rep 5,374
The MMA is designed to cover owners who use replacement parts that meet OEM specifications. Unless you've got proof that the speakers are built to OEM specs, then you don't have much hope of the MMA applying. Plus, you've coded the car yourself, not BMW. MMA has no application here. BMW warranty is there to cover unmodified cars. You've done coding, have replaced the speaker with non-OEM parts, and you've played around with speaker wiring harnesses. The coding is the big kicker here, thus I can see BMW's point.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
10-30-2018, 09:16 PM | #18 |
99
Rep 160
I always find it interesting people are so quick to jump on a manufacturer as an evil corporation bent for denying warranty coverage on everyone. Put yourself in their position - you have a product that you have full confidence in, to the point you are offering a 4 year warranty on it. People start buying your product and start adding parts to it, changing the programming, i.e. doing things that you could not have accounted for in your warranty. Now something breaks, and they expect you to still warranty your product even though you don't know exactly what was done, how the parts could have interacted with your product, or if something got botched during the installation. My point is, they are not evil - in contract terms you are in breach and "released" them from their obligation for providing the warranty for you.
In your case, even if the speakers are completely the same specification as OEM, who's to say you didn't accidentally short the terminals with a screw driver during installation with the amp powered on? Could that have caused a problem? Potentially... Or the speakers could have been poorly made and coil insulation was compromised and your speakers are now intermittently shorting (as the car/coil moves). My point is, these are possible scenarios that are all within the realm of possibilities. From BMW's stand point, I could see some justification for refusing warranty coverage. Now that there's coding involved - I hate to break it to you, they will probably deny this warranty coverage, and potentially any ECU related issue down the road. |
11-12-2018, 10:27 AM | #19 |
32
Rep 51
For what it's worth, Advantage BMW (Midtown/Downtown) is my dealer as well. I have had several issues with the service department for my 1+ year of ownership, including taking a week to solve a simple problem, misdiagnosing issues constantly, damaging wheels during tire replacements, claiming to have parts in stock that they did not, and a few other small issues. The dealer location is good for me, but I'm close to considering going to the Momentum dealer on 59S or elsewhere. I also think they grossly overprice used models, underpay on trades, etc. I was slightly disappointed with my buying experience and have been beyond pissed with the service center on occasion. That being said, the management personnel has stepped in several times to solve my problems after the fact. I just wish they hadn't happened in the first place and it has become a recurring issue that speaks more to the shop as a whole.
11-12-2018, 03:36 PM | #20 | |
272
Rep 823
11-12-2018, 09:51 PM | #21 | |
Rep 13
11-14-2018, 10:19 AM | #22 | |||
5559
Rep 5,374
The MMA was enacted so that automakers did not have a monopoly on parts to service vehicles and so that owners had choices when it came to buying parts and servicing their cars and doing the work themselves if they so choose.
Viffermike1753.00 Poochie9104.50 |
