Possible Tune Thoughts
09-27-2018, 07:54 AM | #1 |
Rep 25
Hey All
I just picked up a 12 335is with a fresh factory long block, 70K on the clock and 3500 on the engine. Want to do a mild type tune and was looking at the AFE 5R intake and the Burger JB+ plug and play tuner. Anyone running this? What do you think the total HP gain would be? The book say the 5R is 27HP and the tune is max setting 40HP. Thank guys |
09-27-2018, 08:57 AM | #2 |
540
Rep 1,040
From my experience, I suggest going with MHD instead of the JB+/JB4. My 335is ran like shit with just a JB4.
Intake is not going to add 27hp. If you're only looking to go with a mild tune, intake will only add 5-10hp at most. My guess is that Stage 1 MHD+Intake should net around 40hp.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
09-27-2018, 09:19 AM | #3 |
Rep 25
I can look at the MHD stuff. I just liked the JB4 sisnce i can remove it easily. Yeh never thought I woukl get the full HP out of any of these but was curious what others saw. What intake are you running?
09-27-2018, 09:43 AM | #4 | |
2657
Rep 6,290
And since I was putting down pipes for louder exhaust I'm now going to go MHD Stage 2 probably. Also was like you JB4 thought was the best but it seems MHD is pretty good, simpler and better. |
09-27-2018, 09:45 AM | #5 |
540
Rep 1,040
MHD is a lot easier to 'remove', you can do it from the comfort of your driver's seat lol. It's also cheaper, even if you don't already have an Android device. I have nothing bad to say about BMS, the JB4 worked great on my '09 335i N54. It's just that I wasn't able to get it working properly on my 335is even after a few back and forths with their support team. I am still using the JB4 now, but I'm using an MHD back end flash with it which means MHD is doing the majority of the engine control.
I have the BMS dual cone intakes, nothing special but they get the job done. aFe is definitely the best option available today, however I couldn't fathom paying 5x the price for the minimal gains intakes provide. aFe's closed box intake does provide colder air to the turbos, which not only increases power but also helps increase the life of the turbos.
Antetokounmpo1551.50 |
09-27-2018, 09:50 AM | #6 |
772
Rep 1,418
JB4 is a boost controller, MHD is a true ECU tune and way better in my opinion.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
Antetokounmpo1551.50 allcaps5512.50 |
09-27-2018, 10:07 AM | #7 |
164
Rep 2,556
GIAC Does anyone use this flash anymore? It's been flawless on my car for 8 years.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
09-27-2018, 10:35 AM | #8 | |
Rep 25
09-27-2018, 10:43 AM | #9 | |
540
Rep 1,040
With only 3500 miles on your new motor, I think aFe would be worth the investment. I had 55k on mine so I wasn't as concerned, there's no telling when they'll go so I'm just preparing to go ST for when my little snails die on me.
09-27-2018, 10:44 AM | #10 | |
2657
Rep 6,290
I had same opinion as him BMS DCI intake were 100$ and all the other nicer intakes were like 350$-400$-500$. At that point you are just paying for visuals IMO. EDIT: And sligthly more HP due to colder air a bit Last edited by TheMidnightNarwhal; 09-27-2018 at 10:52 AM.. |
09-27-2018, 10:55 AM | #11 | |
540
Rep 1,040
They're also blue and the BMS filters are red. Normally red is faster but when it comes to BMWs I think blue is faster. Not proven though.
RB 2+, Wedge tuned. E85 PI coming soon. Last edited by b92; 09-27-2018 at 02:50 PM.. |
09-27-2018, 11:04 AM | #12 | |
2657
Rep 6,290
Actually, true if you have your BMW roundels blue stock. If you change them for another color, then the red filters give you the full power. |
09-27-2018, 11:17 AM | #13 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
MHD, especially if you're DCT. It can be as mild or wild as you want it to be. Just be aware whatever tune you decide on will negate the 335is factory "tune", it's not stacked, just like whatever you read about a HP bump from a intake.
Your factory intake with a drop in will work just fine until well north of 400whp, it's just not as sexy. Drop the money on a good 7" intercooler first instead.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
09-27-2018, 01:02 PM | #15 | |
Rep 25
PS where in Fl are you located? |
09-27-2018, 01:16 PM | #16 | |
Sua Sponte
1299
Rep 2,850
I'm in the Tampa Bay area.
09-27-2018, 01:38 PM | #17 | |
Rep 25
I see you tarck your car so was wondering if you were down SE. I am usually running around WPB, Homestead and Sebring in a Black 02 M3 |
09-27-2018, 03:04 PM | #18 |
540
Rep 1,040
Yeah, flashing back to stock with MHD yields the same results as uninstalling a JB4, just a lot less work!
09-27-2018, 05:24 PM | #19 | |
253
Rep 410
It absolutely does. |
LMB335IS1299.00 |
09-27-2018, 05:52 PM | #20 |
2657
Rep 6,290
09-27-2018, 05:52 PM | #21 |
Sua Sponte
1299
Rep 2,850
I track it at the 1/4 and 1/2 mile events. It's had brake and suspension upgrades done but it's not track ready. I'd need a different wheel/tire setup and move away from the BMW Performance springs and shocks to something a little more serious.
09-27-2018, 05:54 PM | #22 |
Sua Sponte
1299
Rep 2,850
Lol, you should probably google BQ Tuning before you say any more. @BaaQaf
IllSic_Design2124.00 |
