09-26-2018, 10:30 AM | #1 |
80
Rep 147
M2C suspension / small upgrades
hi, i want to lower the car a little bit ( approx. 20mm) and install semi slicks, michelin pilot sport cup2 or pirelli trofeos. what kind of small-budget big-impact suspension mods are recommended? less roll, less chassis movement wanted..
anti roll kit / sway bars: - there are Eibach, H&R, Dinan and other sway-bar sets, which is the best? - is the roll-bar-diameter at the M4 CS / GTS different? will it fit at the M2C? - or is it possible to fit the OEM M4 convertible anti-roll-bars? higher diameter? what kind of spring setup is tested at the M2 with sway-bars? - height adjustable version? vs standard spring.. best, c |
09-26-2018, 10:46 AM | #2 |
4401
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Interested! Following...
I think an adjustable suspension kit is a definite go. I would love to know what you guys would fit additionally. MR |
09-26-2018, 11:42 AM | #3 | |
80
Rep 147
a friend install height adjustable kw springs at Nissan GTR and Porsche 911.2 all the time and tell me it is the best improvement for your money for sure.. but, height adjustable springs + sway bars (anti roll kits) is i think 1.5k.. therefore a discussion is needed IMO, i'd like to hear your experiences... |
09-26-2018, 12:02 PM | #4 | ||
4401
Rep 2,856
MR Last edited by MR.; 09-26-2018 at 12:07 PM.. |
09-26-2018, 12:06 PM | #5 | |
80
Rep 147
http://www.ast-suspension.com/websho...-m4-f82-detail |
09-26-2018, 12:22 PM | #6 | |
80
Rep 147
michelin pilot sports cup 2 will improve the grip level of the M2C for sure. with sway bars you should feel better cornering even every entering or leaving the highway, otherwise is not worth it.. but i do not know about traction, acceleration out of corners .. if the rear axle become more rigid .. in my country min. 100mm ground clearance is needed, so for optical and technical reason i want approx. -20mm and most important for me avoiding bodyroll |
09-26-2018, 12:48 PM | #7 | |
80
Rep 147
i guess same expensive as kw clubsport!? that invest is 3x as expensive as springs and sway-bars?! if the result is significant faster or significant better handling as "springs and sway-bars"??? |
09-26-2018, 12:54 PM | #8 |
80
Rep 147
09-26-2018, 12:56 PM | #9 |
80
Rep 147
i want to deal with higher grip of Michelin Cup2 and avoid roll.... but not lower than 100mm from ground left, -20mm maybe -25mm max.
09-26-2018, 01:02 PM | #10 | |
80
Rep 147
09-26-2018, 01:06 PM | #11 |
80
Rep 147
copy that for daily driving but not if you aim some corners... if you load the tyre a lot it gains temp. fast, 1550kg and OEM size .. is no alfa 4C or lotus elise/exige mate
09-26-2018, 01:26 PM | #14 | |
80
Rep 147
that was 1er M against e92 GTS.. pirelli corsa system was.... |
