09-25-2018, 10:00 PM | #1 |
37
Rep 48
Recall: Fuel Level Sensor
I received the recall letter today for my FE. It states:
What could happen "The fuel level sensor in the fuel tank may contact and become stuck against an in-tank fuel line. If this occurs, the fuel gauge in the instrument cluster would display a constant (and larger) amount of fuel than is actually available. This could lead to stalling, and increase the risk of a crash." Has anyone received this letter and had it fixed? Sounds like the car needs to be ripped apart to fix the problem.... at least to get to the gas tank! I don't even want people touching this thing let alone rip it apart. Not good BMW! |
09-25-2018, 10:08 PM | #2 |
2594
Rep 2,683
Drives: '24 X7 M60i
I had this problem in my E46 M3 back in '03. Just be glad there is a recall because that means they have a solution.
When I had the problem they didn't have a clue.
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
09-25-2018, 10:09 PM | #3 | |
BMW Fan Boy
446
Rep 1,385
09-25-2018, 10:19 PM | #4 |
162
Rep 329
Got the letter yesterday and made an appointment for next week.
I was told it takes an hour to complete so I don't think the car will need to be taken apart. |
09-25-2018, 10:34 PM | #5 |
21
Rep 53
Already had this done a week ago. I believe it is a quick fix (probably a couple hours) but my service center was booked up so it took pretty much two business days.
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl |
09-25-2018, 10:35 PM | #6 |
183
Rep 795
They need to take out the back seat, and then open the area under the seat to get to the gas tank. I'd expect some damage - I have bad experience with dealerships even on much more trivial stuff.
10-05-2018, 03:21 PM | #7 |
162
Rep 329
Recall service was done today. Took just under an hour.
They did have to get to the fuel tank but no damage as far as I can tell. Only drawback is the car stinks of gasoline so have to leave the windows open. |
10-05-2018, 04:02 PM | #8 |
407
Rep 2,704
My piece of advice when you bring the car in to do this ( which i did)
Make sure the gas tank is less then 1/4 (which i did, no smell) Otherwise you might have the problem listed above /\ |
10-11-2018, 08:41 PM | #10 |
37
Rep 48
I took the FE to dealer for the recall. The mechanic was very appreciative that the tank was pretty much empty. I recommend you do the same to avoid any spillage. The access port to the tank seems to be at a 35-40 degree angle so if the tank is full, it will overflow out. No damage and no ripping of the insulation.
Attached are a couple of pics for your pleasure. Last edited by verdao; 10-11-2018 at 08:49 PM.. |
01-21-2019, 04:44 PM | #11 |
21
Rep 53
Just got done doing a 1200 mile rally (which was a blast in the F90 outside of some scary blizzard highway moments) and I am not convinced the sensor recall was done right or if it is the correct fix. I would fill up 6 gallons of fuel at the pump even though my gas level was showing well above 3/4 full. From what I could tell at each fuel stop it was 1-2 gallons off.
02-04-2019, 08:09 PM | #12 |
283
Rep 288
Drives: 2018 F90 M5
I had the recall performed several months ago after experiencing the faulty fuel level readings. All has been fine for the past 2,000 miles until last week when I got an orange CEL. Car is now at the dealer and the code the car is throwing indicates a short in the fuel system electronics. I’ll update when they know/tell me more.
02-06-2019, 12:45 AM | #13 | |
283
Rep 288
Drives: 2018 F90 M5
We certainly are the test mules for the f90! |
02-06-2019, 07:29 AM | #14 |
153
Rep 427
Drives: 2019 M5 Competition
Huh! My CEL turned on last night, but no errors show up in the iDrive system. I wonder if it's related to the emissions data.
02-07-2019, 05:58 PM | #15 |
///M
6652
Rep 3,683
Did you remove upper down pipes?
Life is too short...enjoy your life
///M |
02-07-2019, 08:00 PM | #16 | ||
///M
6652
Rep 3,683
Like to know what exactly was showing on code reader.
///M |
02-11-2019, 09:42 PM | #18 |
283
Rep 288
Drives: 2018 F90 M5
