How much hp/torque can a stock 235 take safely without breaking? |
09-24-2018, 04:09 PM | #1 |
Marshal Of The State
24
Rep 48
I'm simply curious? This is already a fairly stout ride, but I've been digging around trying to find out where that 'fine line' is between just enough and too much.
Whereby too much means its time to beef up the internals. Guestimates? |
09-30-2018, 09:37 PM | #2 |
583
Rep 1,117
Drives: 2015 BMW M235i
probably 550ish whp. The m235i already has some beefed up internals.
10-01-2018, 01:46 AM | #3 |
Rep 44
I've only read that the crank is forged, not so sure about pistons. The N55 is pretty stout, seems the transmission is the weak point. There are a few P2 235s out there running 500whp, 450 wtq safely.
10-03-2018, 08:29 PM | #4 |
Joint Chiefs of Staff
24305
Rep 191,020
I would not go over 450 whp on auto cars ... Manual with upgrade clutch can probably go over 600 whp with the right fueling
ceedawg467.50 |
10-04-2018, 04:02 PM | #5 | |
5559
Rep 5,376
IMO, you're walking on egg shells once you exceed 400whp/400wtq on the N55. The short block of the M235 is fairly stout with its forged crank (same one as the M2, the other N55s have a cast crank), the same rods and bearings as used in the M2 and the S55 in the M3/M4. Even though it's a open deck (just like the N54), you rarely hear of N55s or N54s have block issues. The M235 comes stock with a robust oil cooler and it also has oil squirters in the bores (unlike the more basic N55s). The head is fine and you never hear much about issues with it beyond maybe a VANOS issue which is generally easy to remedy. The issue though is once you really start pushing a motor past about 20% of it's intended power levels, whether it's an N55 or something else, you start venturing into dangerous territory. You can be one tuning hiccup from getting a spun rod bearing due to super knock at heavy boost onset. And yes, N55s have been known to spin rod bearings, both stock and modified. The turbo's life will be greatly reduced if you run it hard. Are there people that push these motors into the 500whp+ range without issues? Sure, but that doesn't mean it can necessarily live a long and happy life with that power. When running that much power, the tuning must be perfect or else one split-second hiccup could mean a $10K+ short block replacement and/or $2,500+ turbo replacement or both. If you have the financial means, go for it, otherwise be happy with the basic mods and make sub 400whp/wtq or buy a used M3/M4 and make 400-420whp/wtq out of the box and reliably make nearly 500whp/wtq with basic mods.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
10-07-2018, 06:10 PM | #6 | |
468
Rep 1,348
I hate to make claims lest I have seen someone personally post their personal experience with the limits. There is always a risk when adding more power. I tend to feel stock is underpowered. We have seen this. However we see the N54 has surprised us all and I would not be surprised if when the fuel limit issue is figured out along with installing a big turbo the N55 will surprise as well.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
10-10-2018, 11:51 AM | #7 |
74
Rep 410
10-10-2018, 02:58 PM | #8 |
24305
Rep 191,020
the auto transmission will struggle with over 450 torque
10-10-2018, 03:28 PM | #9 |
74
Rep 410
10-10-2018, 03:30 PM | #10 | |
24305
Rep 191,020
Its never recommended to push your daily driver to the limit.
10-11-2018, 01:03 PM | #11 | |
20
Rep 58
Never tuned an auto car before, and wanting to have really well defined thresholds. |
10-12-2018, 04:18 PM | #12 | |
5559
Rep 5,376
A conservative tune and DP is as far as I'd ever push any N55, especially one with an automatic. That ZF is a VERY pricey piece to buy used and frightening if bought new (~$11K). The main limiting factor in the 6MT is the clutch which can easily upgraded and the 1-2 syncro if shifted hard often or when the tranny isn't fully warmed up. I'm sure you could break it too with a lot of torque and hard launches. But used 6MTs are plentiful and even a new 6MT is somewhat reasonable at $3,500.
11-02-2018, 07:35 PM | #13 |
40
Rep 218
On-topic question: what about the OEM turbo? Does anyone know the estimated efficiency range of these turbos?
Heading towards the BM3 stage 2 route (91 oct) so I think its important, if not critical, info to have... thanks!! |
11-02-2018, 08:22 PM | #14 |
101
Rep 221
Most people with a ps2 are hitting between 450-500 hp and I haven't read anything bad about it. Bigboost kits are pushing 550ish and stories seem good.
Maybe we only hear the positives and not the negatives. Who knows |
11-04-2018, 06:43 AM | #15 |
1165
Rep 1,931
engine can take 600+ easily.
Auto tranny will throw up right around there, manual will hold a little more. keep it under 25 psi.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
Amack101.00 |
11-06-2018, 12:42 AM | #16 |
97
Rep 373
can the stock turbo hold 18psi comfortably through out the rev range
( i assume the max the turbo can manage is 21psi so don't want to max it out tuners have told me 80% of its max is where they would push the turbo to safely?) |
11-07-2018, 05:00 PM | #17 |
1165
Rep 1,931
up to 22, than your on your own...
www.nybmwcca.org
