Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > No clutch pedal pressure
      09-21-2018, 07:20 PM   #1
Paliator
17
Drives: E90
I just finished replacing my clutch using a luk clutch kit. I also did a clutch delay valve delete while I was there. I went to bleed my clutch after I finished everything, and NOTHING comes out when I bleed it and there is absolutely no clutch pressure at all. Fluid did come out when I did the cdv delete. I would really appreciate some help, I'm dying to have my car back
      09-21-2018, 07:56 PM   #2
feuer
feuer's Avatar
4276
Drives: wife crazy!
Get a vacuum pump. Attached on the bleeder. Loosen up the bleeder. Start working the vaccum pump. Once brake fluid starts running you can start pumping your pedal.
      09-21-2018, 08:05 PM   #3
Paliator
17
Drives: E90
Do you think anything broke? My pedal was very stiff and then all of a sudden the pedal is like butter
      09-21-2018, 08:42 PM   #4
feuer
feuer's Avatar
4276
Drives: wife crazy!
I don't think is broken.
      09-22-2018, 01:16 AM   #5
Paliator
17
Drives: E90
I just finshed trying what you said and it started leaking from this opening in the transmission
https://ibb.co/gNKAbp
      09-22-2018, 11:42 AM   #6
feuer
feuer's Avatar
4276
Drives: wife crazy!
I'm sorry. Probably you broke it.
      09-22-2018, 02:34 PM   #7
Paliator
17
Drives: E90
Broke the slave cylinder?
      09-22-2018, 02:43 PM   #8
feuer
feuer's Avatar
4276
Drives: wife crazy!
If is leaking is broken.
      09-29-2018, 04:51 PM   #9
Paliator
17
Drives: E90
Just replaced master cylinder, slave cylinder, and I still have no pedal pressure. This car is driving me insane.
      09-29-2018, 07:06 PM   #10
feuer
feuer's Avatar
4276
Drives: wife crazy!
After all of this I will suggest you to take it to a mechanic shop.
      09-29-2018, 08:52 PM   #11
Cruiser124
Cruiser124's Avatar
119
Drives: 2006 BMW 330xi 6MT
It really shouldn't be that difficult, it's a Simple hydraulic system. Start at the beginning, do you have fluid coming out of the slave cylinder bleed valve?
Be sure to note that only 1/4 section of the brake fluid reservoir (closest to the firewall) is for the clutch, so when bleeding the clutch you will very quickly run this dry. Are you sure this part of the reservoir is staying full when you're trying to bleed?
      02-18-2019, 11:33 AM   #12
austin.tillison
11
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
I'm experiencing the same exact issue
I did a new clutch and I was hoping to bolt it right back up and be back in business.
My clutch pedal was incredibly firm and wouldn't depress all the way. Ended up blowing my master clutch cylinder pressing so hard on the pedal.
Just replaced the clutch master and slave cylinder and I can't get any pressure in the pedal after trying to bleed it for hours last night.
did you ever resolve your issue?
