09-21-2018, 06:51 PM | #1 |
Rep 23
Log Check Please!
Hi Guys,
I’m new to the N55 engine. Hoping someone can review a log for me. Stage 1 MHD. Just replaced the charge pipe. https://datazap.me/u/m248/n55-ewg-mhd-stage-1 Last edited by M248; 09-21-2018 at 07:42 PM.. |
09-22-2018, 08:34 AM | #2 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
hey a sort of local guy... I just did my charge pipe too.. i think I hit 13.xxlbs boost too.. stage 1 BM3
09-24-2018, 11:32 AM | #4 |
Rep 17
New to the N55 as well.. I don't know anything about the torque limiters but I noticed its during turbo spool up and non existent after that. Intake air temp rises 10 degrees over the pull, but is normal after 5k rpm where the compressor efficiency goes down. AFR concerns me as during spool up the AFR is quite lean and doesn't really get into what I would think is a good AFR. Example: you're hitting 13.5 psi and still have an AFR of 14:1! (are these wide band readings on our N55 engines?) Through out the boost range, the AFR only gets down to 12.3:1 which bothers me. My experience with a different engine (Mazdaspeed 3) Im used to seeing AFR's down around 11.7:1.
Just my thoughts. |
09-24-2018, 11:59 AM | #5 | |
1171
Rep 969
OP log looks about right - your IATs are high and probably causing the DME to pull some timing... you'd benefit a lot from a FMIC.
09-24-2018, 12:08 PM | #6 | |
Rep 17
Thanks for chipping in! |
09-24-2018, 08:10 PM | #8 | |
Rep 23
Didn’t realize the DI was the reason these can run leaner. Thanks for the wisdom! |
09-26-2018, 08:31 PM | #9 | |
Rep 23
I’ll post a few logs after the install! Oh and I wanted to ask, should I opt to try the spring in the DV+? From what I’ve read it help throttle response considerably, but can potentially cause overboosting and related issues during shifting. |
