Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > N54 wont idle
      09-21-2018, 12:37 AM   #1
08TUNDRA
08TUNDRA's Avatar
125
Drives: 2008 e92 335i
N54 wont idle
Hi everyone need a bit of help on what to do next on an n54 that in trying to fix. Tried researching but everyone else doesnt seem to have the same symptoms. The idle on this car is fine for a few seconds when cold, as soon as it begins to drop it begins to jump up and down it drops under 500rpm and alsmot stalls then jumps back up. It does this whether its cold or warm Ac on and off. Just bought the car. Put brand new spark plugs, brand new coils, all new vaccum lines, walnut blast, hpfp is new, swapped out injectors and coded with no change, cleaned the MAP sensors, cleaned the vanos solenoids, swapped boost solenoid. All with not much result . The car pulls hard and is good all stock. Stumped at this point. I attached a youtube video so you guys can see. Any help is appreciated!
2008 E92 335i-MHD FBO-6MT Conversion- CIC I-drive Retrofit
      09-21-2018, 09:43 AM   #2
RomKaN54
Ukraine
23
Drives: 2009 335i 6MT
i have same issue replaced the coils, plugs, and index 12 injectors just improved a little but issue still there.... what i did is used MHD to disable "cold start" and set idle to 800rpm... 2 years running no issues. u in san diego warm climate like me so u will be fine.
      09-21-2018, 10:16 AM   #3
08TUNDRA
08TUNDRA's Avatar
125
That might be what I have to do. Just got the car and wanted to make sure the whole engine was sorted before I tuned it. But hey if a tune can fix it I'm all for it !
      09-21-2018, 10:31 AM   #4
RomKaN54
Ukraine
23
car is ready just pull the trigger!!
      09-21-2018, 10:38 AM   #5
JM98
391
Drives: 2009 135i
I had similar symptoms with a vacuum leak at the throttle body
      09-21-2018, 11:08 AM   #6
arhoads335i
180
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
yup I would guess vacuum leak
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      09-21-2018, 04:34 PM   #7
08TUNDRA
08TUNDRA's Avatar
125
I will very soon!, just gotta make sure everything is sorted and then the mods begin!
      09-21-2018, 04:35 PM   #8
08TUNDRA
08TUNDRA's Avatar
125
Will take a look at that, maybe there is a crack?
      09-21-2018, 04:37 PM   #9
08TUNDRA
08TUNDRA's Avatar
125
Any way to test vaccum leaks on these cars? All the hoses are new.. dont know where to look next.
      09-22-2018, 01:20 AM   #10
Bali
E46 Fanatic
Bali's Avatar
42
Drives: E46 E84 F15
Smoke test for vacuum leaks.
Read the trouble codes and warm idle fuel trims.
