Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Knocking at idle top front of the motor
      09-19-2018, 03:25 PM   #1
malgyver
16
Drives: 2008 335i Sedan
Hello all, thanks for any help in advance. I searched and didn't find much. 335i w/ 150K
I recently heard a new noise....its a light knocking at the front of the engine, hard to tell but it seems to emanate from the timing chain cover or right below the oil filter housing. The top black plastic motor cover is not installed, and hasn't been in a long time.
It sounds the same as when my PS pulley came loose, however, I checked that, and its tight.
Knocks at and off idle, below about 1500 rpm. Otherwise no performance issues.
Any guesses? Is this what VANOS problems sound like? I've never had a problem with those thus far.
I'm going to work on a video in a moment.
Thank you!
JB4, DPs, Style 313 wheels, M-Sport front bumper, Inlets, DCI
      09-19-2018, 03:40 PM   #2
feuer
feuer's Avatar
4276
Drives: wife crazy!
Look at the movements of the belt tensioner and if matches the knocking sound you found the cause.
      09-19-2018, 03:52 PM   #3
malgyver
16
I jacked it up and got under it.
Its sounded like the PS Pulley, because it WAS the PS Pulley. One missing bolt and one loose. I guess a moot post. Moderators can delete I suppose.
When I visualized the top of the pulley, the runout looked about 1/16", so I didn't suspect it. The tensioner also had the slightest amount of movement, but not what I would have expected from that volume of knock..
      09-19-2018, 04:01 PM   #4
feuer
feuer's Avatar
4276
Drives: wife crazy!
"It sounds the same as when my PS pulley came loose, however, I checked that, and its tight."
      09-20-2018, 05:05 PM   #5
malgyver
16
Yes yes yes I know. In my first episode of this, the pulley was so loose I could move it with my hand even with the belt tension. So my first diagnostic procedure was to grab it and try to move it, and it was "tight".
