The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > help me please keeping getting negative timing during wot
      09-19-2018, 12:41 PM   #1
Singleturbo335i
Drives: 2008 bmw 335i
so every time I go wot it either drops -3 on one cylinder, some or all please help! e92 FBO 66k miles! just got done putting it together, it's on mhd v7 stage 2 and v8 stage 2 on data logs. I know its the DME helping knock but whats causing it? when DME corrects its usually IAT, plugs, coils, too aggressive map or trash fuel. I know its not too aggressive map because come on its mhd not no custom map and it has brand new coils and plugs with less than 250miles on them and its not the fuel. i know my IAT's were hot but were the hot enough to pull timing and don't worry 7.5 inch will be here Friday!
LOGS:
https://datazap.me/u/mason54/log-153...og=0&data=3-24
https://datazap.me/u/mason54/log-153...og=1&data=3-24
https://datazap.me/u/mason54/log-153...og=2&data=3-24
mods:
4 bar map sensor
straight pipe
• IGNITION COILS (6 OF THEM) ES: 2919787
• HIGH FLOW FUEL PUMP - 255LPH ES#: 2189784
• 2011 M3 LSD DIFFERENTIAL (3.15 RATIO)
• 2011 M3 HALF SHAFTS (LEFT AND RIGHT)
• 2011 M3 DRIVESHAFT
• MOTIV TWIN DISC CLUTCH ET - BMW N54 1300 TQ CAPACITY
• MOTIV THROW OUT BEARING
• MOTIV PILOT BEARING
• ECS PERFORMANCE CLUTCH FORK PIVOT PIN ES#: 2992391
•CLUTCH FORK LEVER ES#: 41235
• DUAL COLD AIR INTAKE
• BMW FUEL INJECTORS (SET OF 6 FOR N54-INDEX12) - GENUINE BMW #: 13538648937KT
• NGK 93026 DILKAR8A8 LASER IRIDIUM PLUGS 6 OF THEM #: NGK93026 GAP at .022
• HP AUTOSPORT MODIFIED CLUTCH DELAY VALVE
• ULTIMATE SHORT SHIFTIER EVO3 WHOLE SHIFTIER KIT #: USSE335+86-3
• VRSF CHARGEPIPE UPGRADE KIT
• BLOW OFF VALVE TURBOSMART KOMPACT PLUMB BLACK DIVERTER VALVE
• VRSF 3" CAST STAINLESS STEEL CATLESS DOWNPIPES V2 N54 CERAKOTE HIGH TEMP COATING
• TUNER MOTORSPORT SOLID ALUMINUM ENGINE AND TRANSMISSION MOUNT SET T#: 397211
• REAR DIFFERENTIAL MOUNTS - SOLID DELRIN RACE T#: 1453
Last edited by Singleturbo335i; 09-19-2018 at 12:42 PM.. Reason: forgot somethings
      09-19-2018, 01:17 PM   #2
b92
b92's Avatar
540
Drives: E92 335is, 6MT
I'm not an expert here but IATs are entirely too high. Pretty sure MHD's OTS stage 2 maps require an intercooler, if you have one on the way then I recommend waiting to see how that affects things before you go crazy diagnosing this issue.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      09-19-2018, 01:42 PM   #3
arhoads335i
180
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
yeah those IAT are pretty high. It also pulls the timming when the car hits 18psi but recovers from there. Do you have traction control fully off?
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      09-19-2018, 01:55 PM   #4
Singleturbo335i
yeah traction control is off, abs and tc have been disable every since i put the m3 diff in it can't figure out why? (maybe speed sensor because different ratio) but i do have a intercooler right now just stock and if you look at the last data log my iat were high but not as near bad as the first log and why does it pull timing at 18 psi?? thanks for the help too!!
      09-21-2018, 09:24 AM   #5
b92
b92's Avatar
540
At high boost your car is not getting as much air as it thinks it is due to the temps. Try flashing the stage 1 map and see how that goes. Or just install the intercooler and see how that changes things.
