TCU Only to Combox Retrofit questions (CIC Retro Complete)
09-15-2018, 02:03 PM | #1 |
12
Rep 105
Drives: 2010 335i
I have spent hours trying to find a straight forward answer to whether or not after swapping my ccc to cic and coding it if my tcu in my trunk is a direct swap to the combox. I dont have a mulf and want to skip directly over it and remove my TCU to put in the combox. Im assuming that the combox retrofit cable wont work for me so im lost on how I can do this. Any help is appreciated!
09-15-2018, 02:12 PM | #2 |
461
Rep 2,758
why do you think that combox retrofit cable will not work ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-15-2018, 02:19 PM | #3 |
12
Rep 105
Drives: 2010 335i
This is the only cable I can find that mentions working when a car comes equipped with only a tcu. Id prefer to just pull my tcu out and put the combox in and repin it myself. Problem is I can't find a straightforward diy thread that doesn't have a car with both tcu and mulf.
https://www.bimmerfest.com/forums/sh...d.php?t=723325 |
09-15-2018, 02:42 PM | #4 | |
461
Rep 2,758
you need to compare them and repin pins
09-15-2018, 02:49 PM | #5 |
12
Rep 105
Drives: 2010 335i
09-15-2018, 11:38 PM | #6 |
1918
Rep 13,115
https://www.bimmerfest.com/forums/sh...d.php?t=772784
the above also references this https://www.bimmerfest.com/forums/sh...d.php?t=723325 From an google search "combox retrofit" Last edited by ctuna; 09-15-2018 at 11:52 PM.. |
09-16-2018, 05:47 AM | #7 |
399
Rep 1,579
As other have said, just move the pins. The adapters are only needed when the wiring won't reach where it needs to go.
As for USB in the arm rest, you only need that for a one time Bluetooth update to the combox. Your combox may even already have it. To do the update, a generic cable hooked to the combox should work. https://www.amazon.com/EX1-USB-Cable...ywords=bmw+usb |
09-16-2018, 05:49 AM | #8 | ||
12
Rep 105
Drives: 2010 335i
09-16-2018, 11:00 AM | #9 |
399
Rep 1,579
I am not sure but it would be easy to figure it out with a test fit. Most E90 issues were with TCU and MULF where both sets of wires would not reach the same point.
09-16-2018, 11:57 AM | #10 | |||
12
Rep 105
Drives: 2010 335i
09-16-2018, 02:20 PM | #11 | ||
12
Rep 105
Drives: 2010 335i
09-17-2018, 05:52 AM | #12 |
399
Rep 1,579
TCU and MULF use a similar connector. The plastic can be trimmed to make one go into another. Combox is a completely different connector for some reason I don't know.
09-17-2018, 07:24 PM | #13 | |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-19-2018, 12:07 PM | #14 |
12
Rep 105
Drives: 2010 335i
I installed the combox and coded it (at least i thought so) and now i see the options for bluetooth audio, and usb but when i have my phone connected for calling and i try to switch to blueooth audio it asks me to click a box that says activate and when i do nothing happens. I already repaired my phone (note 8) and i enabled bmw apps and wrote it to my cas and nfrm and it doesnt show them. Any ideas? I also have to sos error
09-22-2018, 06:02 AM | #15 | |
18
Rep 315
assuming the wiring is correct then it will be software or the coding to enable... I've never done this, (so feel free to ignore....) but there were always 3 elements to the coding session when doing the mulf 2 high upgrade.... only posting this as no other contributors 1. Add $644 to the VO and do FA_WRITE to both CAS and NFRM. 2. After finishing step 1, change ECU to 2RAD (radio professional) and change job to SG_CODIEREN then execute job. |
12-07-2018, 08:29 PM | #16 | |
Rep 25
Pins 5 & 6 you mention connect to pdc module, where would this be located?...i am installing combox, had tcu & Milf, however cant seem to be able to find CAN HIGH & CAN LOW...any ideas?
cheers jc Quote:
12-08-2018, 06:50 AM | #17 | |
399
Rep 1,579
5 and 6 were not hooked up in either of my retrofits. I think they are only needed if you are trying to get SOS/BMW assist to work. The rows in red above can be ignored. Except for power which I think is on 2 rather than 1 for some versions of the combox. |
12-08-2018, 08:56 PM | #18 | |
Rep 25
cheers jc |
12-08-2018, 10:19 PM | #19 | |
1473
Rep 1,913
1/2 of all customer combox installs I do have the pinout wrong on the first time. I am also 2/2 for customer supplied combox's being DOA. |
jcsydney0.00 |
12-08-2018, 10:22 PM | #20 | ||
Rep 25
12-08-2018, 10:26 PM | #21 |
1473
Rep 1,913
Link removed
If you do not make fun of spelling / grammar mistakes here is the a pre-release of my combox kit install guide. I have not has time to proof read it yet. Once I am done finals I am going to be dropping a lot of diys and redoing some old ones. Last edited by Nickco43; 12-08-2018 at 11:00 PM.. |
12-08-2018, 10:29 PM | #22 |
Rep 25
