09-14-2018, 08:33 AM | #1 |
411
Rep 607
Drives: 2019 BMW M2 Competition
2019 M2 Competition - Drivetrain Malfunction!!!
Ok, so here is what happened.
I have a 2019 M2 Comp, 6MT. Not even for 2 weeks yet. 171 miles. I have been driving very meticulously to follow BMW break in period procedure. Not exceeding 5500 RPMs, not faster than 106 MPH, and driving at varying speed/gears. (not much hwy driving) Anyways, I go to take her on a cruise yesterday, and start her up as always. And almost immediately I received "Drivetrain malfunction" error on the idrive screen! I let it idle, and sounds fine the whole time, and then the error goes away. I decided to go ahead and drive it to the gas station see how it runs. Runs perfectly fine, not even in limp mode as the error is gone. I bring her back home and let her sit for a couple hours and go into sleep mode. I got back out and start her up and the same dang error pops up and I'm able to get a picture this time. Well at this point, I do not want to drive it. I want to be sure everything is good and not to make things worse. I tried the BMW teleservice, but not really sure what that even does, but it just stuck on "starting teleservice" and then went to "service ended". I try to use my programs to read the codes, but none work as they are all for E series BMW. I was able to track down ISTA-D and get it installed. Fault codes are showing 20A203 (Auxilary coolant pump for charge air cooler: Signal implausible) and 20A503 (Turbocharger coolant pump: Signal implausible) Going to try and setup a service appointment to get it fixed. Looks like might be minor to reseat the coolant pump sensor? or maybe replace it if does not respond. Just a heads up for everyone.
2019 F87 M2C, Long Beach Blue, Exec, 6MT 2016 F87 M2 - Sold 9/2018 2014 F22 M235i - Sold 5/2016. Last edited by Shankska; 09-14-2018 at 08:38 AM.. |
09-14-2018, 08:54 AM | #2 |
4450
Rep 7,594
Drives: '19 M2C
I found this for code #20A503
https://testing-public.carmd.com/Tsb...0B17%2002%2015 I found this for code #20A203 Ping this guy and ask if he got this resolved: https://f80.bimmerpost.com/forums/sh....php?t=1483488
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
Threeebowel31.50 |
09-14-2018, 08:56 AM | #3 | |
411
Rep 607
2019 F87 M2C, Long Beach Blue, Exec, 6MT 2016 F87 M2 - Sold 9/2018 2014 F22 M235i - Sold 5/2016. |
09-14-2018, 10:17 AM | #5 |
411
Rep 607
09-15-2018, 02:20 AM | #6 |
4399
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Back to dealer and have it checked!
MR |
09-15-2018, 09:59 AM | #7 |
243
Rep 497
Charge cooler water pump isn't the end of the world. but there is an auxiliary coolant pump that cools the turbocharger after the engine turns off and you have a code for that as well so yeah probably a good idea not to beat on it until it gets fixed you can drive it like a normal human to the dealer though. The turbo pump is only there if you turn off the car for if the turbos are still very hot.
3tekcorps826.00 |
09-16-2018, 08:58 AM | #10 |
411
Rep 607
I did and they are moving it up the chains at BMW. They are wanting to check the ground, signal, and power pins to the pump. Only threw the code twice so far.
Right, universal warning on the idrive to the driver. That is why I read the codes to know specifically what was going on.
M3 Adjuster7909.00 |
09-17-2018, 05:54 AM | #11 |
4185
Rep 3,077
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Subscribed..
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
09-17-2018, 03:06 PM | #12 |
411
Rep 607
I had to pick my car up Saturday, because I had an appointment scheduled this morning for the past 2 weeks for Xpel PPF, tint, and ceramic coating. I will take the car back to them after this week once everything is done. I was not going to reschedule the appt as my guy is usually 2-3 weeks out.
When I take it back, they are wanting to test the ground, signal, and power pins on the wiring to the coolant pump. When I picked it up on Sat, they said they were able to activate the coolant pump with ISTA successfully. I have been driving the car pretty easy, but doubt it will be even 100 miles by time I have it back to them.
09-17-2018, 03:08 PM | #13 | |
4185
Rep 3,077
Follow me on IG
09-17-2018, 11:33 PM | #14 |
1622
Rep 3,402
I get the sense of panic we all get when our brand new car has a problem but really this isn't anything to give a "heads up" about. Drivetrain Malfunction is the catch all alert for just about any problem that a BMW has that needs to be addressed. Car is under warranty, BWM will fix it.
09-18-2018, 07:42 AM | #15 | |
411
Rep 607
09-18-2018, 09:36 AM | #16 |
1558
Rep 2,505
Just do not let them test drive the car. Tell your SA this and mark down your miles. Report back what they find/replace.
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
09-18-2018, 09:41 AM | #17 |
411
Rep 607
Oh I am somewhat known at this dealership. Also I request a specific mechanic that I trust with my car there. They also know not to "detail" or wash my car.
09-18-2018, 09:56 AM | #18 |
1558
Rep 2,505
Awesome, sounds like you have everything under control.
10-03-2018, 04:31 PM | #19 |
411
Rep 607
Ok guys, sorry for the delay on the update. I had the PPF and ceramic coating done and was not able to get another apt scheduled until Tuesday this week. I just picked up the car.
They tested the pins on the coolant pump. Everything was good and I have not received the error since 181 miles. I'm over 400 miles now. They opened a case with BMW and they had a software update they performed to possibly address this. Info attached. No more fault codes!
10-03-2018, 04:50 PM | #20 |
94
Rep 142
I had the same on my 2017 M2 last week. They told me not to worry as the computer indicated just to delete the error. 12th of October I am going in for a software update.
10-03-2018, 05:00 PM | #21 |
411
Rep 607
you had the same codes? or the drivetrain malfunction warning?
