Changing n54 starter--is it original?
09-09-2018, 12:54 PM | #1 |
Fixing stuff is fun.
15
Rep 26
2007 335i, 130k miles, not much records but well taken care of.
Symptom is starter was slow when engine was hot. Replaced ground strap to block but that did not help. Assumed starter was original. But I found steel t10 bolts instead of aluminum t12 bolts holding it on. It's marked Bosch; not sure how I can tell whether it's original or not. I don't see a BMW roundel on it but I'm not sure the original had it either. Anyone know if steel bolts were ever used at the factory instead of aluminum? |
09-10-2018, 06:35 AM | #5 | |
2665
Rep 6,301
09-10-2018, 04:53 PM | #6 | |
1904
Rep 6,968
09-10-2018, 10:30 PM | #7 |
71
Rep 244
I just replaced mine at 130k on my 09 335i. My OE starter was a denso. Replaced it with a new Bosch unit. I did notice that the solenoid on the bosch was much larger than the denso. Also, the replacement starter bolts I bought had a larger head on them than the ones I removed.
