09-09-2018, 06:01 AM | #1 |
446
Rep 1,369
Chunked: MPS4S
At a track weekend this September, a less than two month old MPS4S tire chunked. One chunk actually revealed a chord so I guess the life of this tire has come to a very short and unhappy end. I was running 38PSI hot on the tire that died. PSI seemed reasonable but there was no doubt the tire was rolling over itself. I guess a hot temp of 40-42 might have been a better choice despite the greasiness I feel as they warm up after a few laps.
Any suggestions on how to prevent 'chunking' in the future at a track day with these tires?? Thanks. |
09-09-2018, 06:54 AM | #2 |
3074
Rep 5,577
On which kind of turns was the tire rolling over itself like in an auto-X ? If it was a rather slow very tight bend under hard braking - then sometimes driving style changes ( minus suspension changes ) and of course tire inflation.
09-09-2018, 11:35 AM | #3 | |
4393
Rep 3,496
How did you determine that you were running 38 psi hot? There are quite a few photos across the 'net showing chunked, corded, and otherwise used-up MPSS' after a single track event. The 4S is susceptible to the same issues. Lack of negative camber, too-high or too-low tire pressures, over-driving the car into the corners, and street braking will all contribute to heating the tire to a point where it gives up. I've come to the conclusion that street tires in this category aren't suitable on race tracks when placed on relatively heavy, high-horsepower cars.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
09-09-2018, 12:23 PM | #4 | |
1399
Rep 5,262
Changing your driving style would help, do very late apexes and sharp turns at lower speed instead of plowing into corners But the real answer is to use a different tire |
09-09-2018, 01:22 PM | #5 |
174
Rep 400
Extreme performance tires will hold way better for track use.
Or drive at little slower pace at the track. MP4S can be rolled over badly. I auto crossed with MPSS and I had to pump up to 48psi hot in front. Now with RE71r, I can stay at 32psi hot. (or even lower) |
10-07-2018, 08:33 AM | #6 | |
609
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
10-09-2018, 02:41 PM | #7 |
1165
Rep 1,931
get a tire made for the track.
re71r's, nt01s, direzzas, etc...
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
10-15-2018, 07:24 PM | #8 |
26
Rep 44
MPS4S are wonderful tires for the street, great grip in the wet and super smooth and quiet. Love em and enjoy the n the street. Get a 17 inch square set up and 225/45/17 Potenza RE71 for the track. They are noisy pick up debris sand like a wheel bearing is going out and sick like glue. MPS4S will help you to enjoy the RE71s and visa versa. you'll need a harbor freight 1.5 ton jack and torque wrench too ..
