The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Question about Upgraded rear shock mounts
      09-08-2018, 12:10 PM   #1
boosthead
40
Drives: 2009 328ix
Do you use the rubber sealing grommet when using poly or monroe rubber rear upper shock mounts, or are they eliminated with that upgrade?
      09-09-2018, 12:53 PM   #2
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
You still need it with the Monroe kit (not sure about poly mounts).
Also, if you get the Monroe kit, reuse the stock metal cup (33526764418) instead of the included washer so that the bumpstop isn't loose. I painted mine since they can be prone to rust
      09-09-2018, 09:19 PM   #3
boosthead
40
Drives: 2009 328ix
Thanks for the tip.
