How long do coilovers last?
09-05-2018, 04:48 PM | #1 |
19
Rep 46
I currently have BC coilovers on my e90 get them about a year and a half ago only have about 20k miles on the coilovers. The ride quality of these coilovers were horrible from the start. Pretty bouncy even on the stiffest setting But recently I noticed the car legitimately bounce now. As if one of the shocks are blown out. Any bump in the road and body starts bouncing up and down my seat. I do recall a Shop telling me i’d Need new lower control arms soon can this be it? Or can it be that the shock blew out already? I’m not maxxed out at all on the coilovers still have about half an inch all around
09-06-2018, 02:59 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
I have my Ohlins R&T serviced every 50K miles...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
09-06-2018, 10:24 AM | #3 | |
BMW Portland
224
Rep 524
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
09-06-2018, 10:27 AM | #4 |
Clean is the new cool, keep it that way.
808
Rep 1,685
BC is crap, no surprise there. I have a few years, probably 30k or so on my Bilstein coilovers.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
09-06-2018, 10:52 PM | #6 |
2188
Rep 5,002
Bouncy ride indicates damper issue. Coilover life varies hugely but a big factor can whether or not they use monotube dampers or twin tube and build quality. There are mono tubes that last longer than twin tubes but often do so at the expense of ride quality due to seal stiction.
Generally, Koni yellow based twin tubes coil overs have the longest service life if you take into account % of performance maintained Into the life of the set up. In this case the ‘coilover’ lasts similar (75k miles-ish) to shock and spring bc they’re essentially the same thing. Anything with a monotube set up that has low stiction seals (aka, not bilstein) generally lasts 15k-50k depending on how fancy they are. ANd the bilstein B8/6 based stuff can last up to 100k but I’m personally of the belief that the ride quality is too stiff to be worth the trade off. Which is why I’m always coming back to the Koni yellow based set up. One potential have your cake and eat it too would the Fat cat motorsports bilstein based set up, but who knows reliable mileage out of that. Last edited by tlow98; 09-06-2018 at 10:59 PM.. |
09-08-2018, 09:21 PM | #7 | |
17
Rep 130
I too have BC Racing coilovers on my 328xi, along with 18s and I can't stand the ride around NYC. I bought the car with them installed and have no idea how many miles are on them. I dislike it so much I'm swapping them out for OEM or slightly more sporty than OEM. Good luck |
09-09-2018, 02:56 AM | #8 |
559
Rep 1,502
Drives: F36 435xd
My Bilstein B16IRC fronts lasted aprox 120.000 km. Just had them changed.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
09-13-2018, 07:27 PM | #9 | |
19
Rep 46
09-14-2018, 10:15 AM | #10 |
808
Rep 1,685
Talk to your local racers, there may be a rebuilder locally but it depends on what dampers you have, most require you to send them back to the factory where as there are far more rebuilders for higher end dampers like Bilstein, Ohlins, etc.
09-14-2018, 01:59 PM | #11 | |
BMW Portland
224
Rep 524
If you plan on holding on to a car for a while after installing coilovers, typically its best to find a brand that is US based and will service them for a reasonable cost. I know Fortune Auto does this with their coilovers and they have a quick turn around time for rebuilds and the prices are very reasonable.
10-11-2018, 02:00 AM | #13 |
2896
Rep 3,726
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
10-11-2018, 03:03 AM | #14 |
616
Rep 3,194
I'm based in the UK, and my nearest Ohlins agent does it. Details of suppliers worldwide are available on the Ohlins website.
