BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      06-29-2008, 11:31 PM   #1
M3Mikey
39
Drives: Jet Black E92 M3 Fox Red Inter
best way to launch
hey guys, this is my first sport car ever and stick shift. I think i chose well.... My question here is how do you launch your car properly.. what is the right rpms and is it bad for your car. can someone do some explaining, i am new to this.
Thanks,
Michael
Jet Black with Fox Red ext. Interior
      06-30-2008, 07:27 AM   #2
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
41
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
Not sure of the actual RPMs since I am always looking at traffic and not my Tach, but I would say mid 1000's as a guess.
The trick to getting the car rolling is to give it enough gas to keep the car from stalling, but not so much that the car takes off on you. After you get used to it, try not to slip the clutch to much (because you will while you are learning). Good luck, and it isn't that difficult just takes a little bit of practice. My first car was a lot harder than this to learn on and I figured it out without ever having to replace the clutch down the road.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
      06-30-2008, 08:07 AM   #3
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
41
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
I decided to take a quick trip to give you more info. I looked at the tach as I took off and it was consistantly around 1200 rpm.
      06-30-2008, 09:44 AM   #4
M3Mikey
39
thanks for the info man. I'll be out to try today.
      06-30-2008, 10:02 AM   #5
Mack211
Mack211's Avatar
23
Drives: 2008 M3 - DCT
I think he is referring to a launch for best off the line acceleration, not regular day to day driving....
2008 M3 Space Gray, Black, Syc Ant Wood Trim, DCT
2001 325ci Steel Gray - Sold
      06-30-2008, 10:22 AM   #6
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
For a fast launch, you probably want to be more like in the 4000 rpms and let go off the clutch pretty quickly--but not to the extent that you dump it. That said you don't want to ride the clutch either. Somewhere in between dumping and riding it. You should get "some" wheel spin, but not too much. If you get too much wheel spin you need to back off the gas a little. It's okay/desirable to get some wheel spin as long as the tires grab on pretty quickly. Don't do this too often or you'll wear off your clutch prematurely however well you execute it.
      06-30-2008, 10:32 AM   #7
!Xoible
832
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
i found anything over 3500 is too much wheel spin. i need to get the right amount of clutch too. i tried launching at 5500 when racing with 2 M6's on saturday. had a better launch than both, but the 3 of us had ridiculous wheel spin. (fwiw i beat both, but i think if i were driving either i would have easily beat my m3)
      06-30-2008, 10:41 AM   #8
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
41
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
Understood. Well then, I haven't tried this for myself but Road and Track says "With MDrive, we can disable stability and select ultimate sport mode with one button. Rev to 3900 rpm and quickly release the clutch while rolling into the throttle. Shifting at redline requires only light lever pressure."
I attached the Data Sheet from their website. Good luck, and let me know how it works out.
      06-30-2008, 10:45 AM   #9
Big Windy
Big Windy's Avatar
152
Drives: None
That's a DCT car, though...or no?
      06-30-2008, 11:42 AM   #10
AwesomeM3
AwesomeM3's Avatar
1641
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
The .pdf file says "6-speed manual", so I don't think it's a DCT car.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
      06-30-2008, 05:24 PM   #11
Blip Bavarian
salivator
Blip Bavarian's Avatar
38
Drives: 16 GT4, 14 X5 V8 & 91 E30 LS1
i think 3500 is about right. Also MDM works best for a clean launch.
      06-30-2008, 05:33 PM   #12
!Xoible
832
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
have u tried launching with DSC off?? it's the awesomest thing ever. i tried it when there were cars next to me, my car started fish tailing left and righ. other cars go scared
      06-30-2008, 07:09 PM   #13
lucid
lucid's Avatar
374
MDM keeps things nicely under control, but if you want the fastest launch possible and can handle the throttle yourself, you want DSC off. It makes a major difference.
      06-30-2008, 08:19 PM   #14
SS32
SS32's Avatar
156
Drives: 2008 M3
For a regular "launch" it should be well below 1000rpm. You don't need much to get the car going unless you're on a hill. Too much will shorten the life of the clutch. A good fast launch is somewhere between 3000 and 3500. It's hard to keep the wheels from spinning free, though.
m3post
