Coilover Theory 101: Coil Spring Comparison
09-03-2018, 08:12 AM | #1 |
581
Rep 1,421
Hey guys,
we get asked questions about coilovers, how they work, how they are manufactured, valving theory etc etc on a daily basis, so this gave me an idea; why not make a 101 separated into several, easy-to-read parts? If you like where I am going with this, please do let me know and what "topics" you would like me to cover, and I'll see what I can do one of the questions that we get asked quite often by our customers is what is the difference between Swift Springs and the generic Taiwan springs (found on nearly all non-European coilover kits), and what makes them so much more expensive? to answer these questions, we decided to do a comparison test, and the results are below. What you make of these results, that's for you to decide: Side-by-side comparison - Swift 7" 10K on the left, generic Taiwan 7" 10K on the right. Notice the difference? Testing the Spring Rate accuracy on our Intercomp Spring Rate Tester, the Swift is exactly 10K: And for the generic Taiwan spring, it comes in at 10.25K (15lbs stiffer than rated): Both are pre-loaded 1" then compressed 1" to get the measurements. Can you say "coil-bind"? Some have questioned us about the accuracy of the Intercomp Spring Rate Tester, so instead here is a dyno graph of a 100lb sample Swift Spring from our Roehrig Spring Rate Tester, showing the Spring Rate (lbs/in) over an increasing compression force (lbs): For the weight test, the Swift comes in at 1.1kg: And the generic Taiwan spring comes in at 1.6kg: The conclusion from all of these tests? Not only are Swift Springs 50% lighter and extremely accurate (you ask for 10K, you get exactly 10K), they also help reduce coil-bind (i.e the coils hitting each other over large bumps). The Taiwan spring? Maybe after 6 months of driving, it will finally be 10K, then 6 months later, 9K! I've deliberately made this post short and sweet, so as to encourage questions, so if you have any, please feel free to ask! |
09-03-2018, 09:49 AM | #2 |
619
Rep 1,402
I would like to see a re-test after 6 months of use of both springs and see how they 'settle'.
If you have less travel to bump stops or shock bottoming than distance for coil bind, it doesn't matter. It would be nice to measure the length to coil bind. It probably is not even an issue as suspension travel will be less. |
09-03-2018, 09:57 AM | #3 | |
581
Rep 1,421
Provided all things equal (the length and rate of the spring), the more sprint stroke you have, then the less chance of coil-bind. In the comparison image above, that was compressed only 2" in total I have all the spring stroke figures etc for the Swift Springs. If you need a figure for a certain rate/length, let me know |
09-03-2018, 12:21 PM | #4 |
3973
Rep 7,215
awesome. I'm so tired of all the kids recommending cheap garbage "BC/Fortune Auto/etc" coilovers (all basically the same thing with a different sticker on the box). You can hardly even buy decent struts/shocks for what some of those kits cost - but they probably don't know what coil bind is anyway, and don't care as long as it's low.
Marty, good spring steel doesn't really settle significantly. That's pretty much the reason they use steel and not whatever is in those cheap knockoff springs.. |
09-03-2018, 12:58 PM | #5 | |
581
Rep 1,421
If the community decides they want it, the next part in this 101 was going to be valving theory, where I will go into detail on how a damper functions, how the valving affects it, and post up all the dyno graphs that I've accumulated over the years. |
zero2sixtyZ951.00 6ixSpd6015.50 |
09-03-2018, 04:57 PM | #6 |
619
Rep 1,402
My Eibachs settled about 1/2-3/4" over abut 5 years. Now they are just where I wanted them originally and the car sits perfectly.
Now if I only had adjustable perches for the rear springs. |
williamt111.50 |
09-03-2018, 09:08 PM | #7 |
581
Rep 1,421
09-04-2018, 02:02 PM | #8 |
Save the manuals!
6016
Rep 6,746
It is more likely that your strut mounts degraded over time, that's a very common cause of ride height loss when nothing has been changed.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
09-06-2018, 08:21 PM | #11 |
1207
Rep 2,026
I used the ycw spring rate calculator on your new website and got completely different results then when I do the calculations by hand. Can you cover relativity of spring rates and spring rate theory? E.g. what is spring frequency and how does it relate the vehicles weight and suspension geometry to the effective wheel rate?
