Bimmertech amp hi fi stereo vs e90 HK
09-02-2018, 08:57 PM | #1 |
248
Rep 824
Hey guys
I have a e90 with the hifi stereo which much say is prettt nice sounding!! Would the bimmertech amp male the sound better than the base e90 hk system? If I keep my car I was thinking bimmertech amp and ghost woofers - to start then maybe the door speakers...
2011 335 Msport Xdrive
Space grey purchased on 8/7/15 |
09-03-2018, 12:26 AM | #2 |
1918
Rep 13,117
First of all your terminology is somewhat confusing.
BMW makes three system (at least those are the common ones) Base system no amp no tweeters. Hi Fi tweeters and a 6 channel amp HK =top hi fi or logic 7 (and a enhanced verstion)13 or 11 speaker 9 channels Which one did you start with. Bimmertech uses the Helix 82dsp or 86dsp last time I looked. Helix also has a BMW7 now. Bimmertech gives you a compete amp kit . There original kit was for the Hi Fi system they also make a kit for the base system.(with the base system they also give you coding to Hi Fi or did) They also have there own speakers now. For speakers I would suggest speaker kits from Helix , Gladen or Audio systems. If you really want to go high end Jehnert and Morel. You might call Unexpected Creations and talk to Don about a kit. Most people report the Helix amps to be way better than HK with decent aftermarket speakers. https://www.e90post.com/forums/showthread.php?t=1530303 Actually the Hi Fi is pretty mediocre at best falls right apart when you turn it up. Ear fatigue at slightly loud volumes. I had one. Last edited by ctuna; 09-03-2018 at 12:38 AM.. |
09-03-2018, 01:11 AM | #3 | |
461
Rep 2,759
and bimmertech and helix are plug and play upgrades for bmw hifi system while for HK install you'll need add 3 channels and replace all speakers and amp from other side there is bmw individual/EPS audio system which have more powerful amp (800W) and high quality speakes
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-03-2018, 04:10 PM | #4 |
248
Rep 824
Thanks guys- for clarity I have hifi stereo without the front center speaker - so amp, rear deck speakers , front door speakers , teeters, and subs under seat-
So trying to think first step- bimmertech or nav auto amp? I really like how the hifi sounds , it's really good for a stock system looking to improve it
09-04-2018, 12:50 AM | #6 |
461
Rep 2,759
bimmertech or audiotec bmw 7up is best first step for hifi upgrade
09-04-2018, 04:41 PM | #7 |
248
Rep 824
Is this a center speaker in my 2011 hifi set up? I can't tell if it's a speaker in there or not?
[IMG][/IMG]
09-04-2018, 04:43 PM | #8 |
248
Rep 824
So not nav sound ? Go with bimmertech amp?
09-04-2018, 05:13 PM | #9 |
1918
Rep 13,117
what is a Nav Sound since I have never heard of one .
Show a link. (Since I can't find it in a search) Its not something that has ever been mentioned here as far as I can tell and usually the better stuff is. No e90 with Hi Fi has a center speaker only the Logic 7 does if if is had one there would be grill in the center instead of solid plastic. Center speakers are overrated. Last edited by ctuna; 09-04-2018 at 05:31 PM.. |
09-04-2018, 08:39 PM | #10 | |
248
Rep 824
You are the resident audio pro, what you say? Bimmertech amp and speakers? The entire package is like 2000 (includes the rear deck speakers)
12-01-2020, 07:26 PM | #12 |
Rep 6
Bimmertech amp and bluetooth module
Hey guys, i'm new to car stuff.
I just bought bimmertech amp which is basically Match pp86dsp amp. https://www.audiotec-fischer.de/en/m...fiers/pp-86dsp So the question here is, will the Bluetooth module for match amp fit in my bimmertech amp? Bluetooth module ==>https://www.audiotec-fischer.de/en/m...ec-bt-pp-86dsp The guy in bimmertech amp said they haven't tested it, so they don't know it for sure. |
12-01-2020, 10:12 PM | #13 | |
tends to get irritable
202
Rep 798
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
12-02-2020, 12:13 AM | #14 |
Rep 6
Do i have to do any coding after i install it by myself?
This is the only guide that i can find in youtube: https://www.youtube.com/watch?v=-QAGlNrcZ9s Thank you in advance! |
12-02-2020, 07:45 AM | #15 | |
202
Rep 798
12-03-2020, 05:02 AM | #16 | |
Rep 6
“ We checked it with our technician. Unfortunately our amp is modified so it won't work with any Bluetooth modules.” But audiotec fischer reply me with this: “ You can use the MEC BT module for the PP 86 also in your Bimmertech amplifier (please make sure that you have the PP 86 and not the PP 82DSP.” Whom should i trust? I’m confused, and the bluetooth module isn’t cheap, it cost 275usd in my country |
