2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Spark Plug Question N55 Plug #5/ #6
      09-02-2018, 10:03 AM   #1
Sylverlee
150
Drives: White 535i M-Sport, 911 GTS
Can anyone help me with some pointers in how to get to the third screw in the back when removing the tubes above spark plug #5 #6? Even forcefully moving the tubes, I still can't fit a torx driver in there.
      09-02-2018, 04:03 PM   #2
NinetyEight740
NinetyEight740's Avatar
231
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Put socket into screw, loosen screw... I find it easiest to go under the harness and lift them up and wedge your socket in there. Or a socket and swivel.
      09-02-2018, 06:15 PM   #3
andykap
21
Drives: '15 BMW 535 MSport
You have to remove the two plugs, the cables run in plastic channel which have two screws on the right, also the air intake. After remove the protective foam then you will have access to those two screws. You will need an angle drive because the space is tight. I just changed mine a few weeks ago.
      11-18-2018, 08:43 AM   #4
whinojosa
21
Drives: 2011 535i (6sp)
2011 BMW 535i  [0.00]
Just did plugs yesterday. Memory still pretty fresh! Yes you'll need a universal joint.
My third screw was stripped so my T25 couldn't grab a hold of anything. You may be finding the same. I looked at the screw from the front of the engine toward the back with my view going under the cables and had to use channel locks as luckily the knucklehead before just gave up on getting that screw back in.
5post
