M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Engine problem: lci m2
      09-01-2018, 03:11 PM   #1
bmwizgoat
11
Drives: 2017 sti
So about 2 weeks ago I noticed upon cold start, the revs would drop after about 2 seconds (which is Normal) but it dropped significantly more then usual. Like it almost stalled. Today I went to start it up and it did stall. Just wondering if anyone else has had this happen and what is likely the cause ? I didn't have any engine lights or anything on either. On a side note, how do I get the tire pressures ? All it shows is green lights on all 4 corners. Thanks!
      09-01-2018, 03:43 PM   #2
M2guru
384
Drives: 2018 M2
2018 BMW M2  [10.00]
I have had no similar issue. 9,500 miles.
      09-01-2018, 03:44 PM   #3
bmwizgoat
11
Drives: 2017 sti
I should add I'm only at 6000 kms
      09-26-2018, 03:00 PM   #4
stefan
stefan's Avatar
No_Country
2350
Drives: M2 Comp
Go for a drive, get the oil warm, floor it in fifth gear from 1500rpm to redline a couple times. Report back. Sounds like adaptations to me.
///M Power
      09-26-2018, 03:04 PM   #5
Slaney
208
Drives: 2019 M2C
14000 miles. Flawless...
      10-06-2018, 05:03 AM   #6
tranck
tranck's Avatar
501
Drives: 2018 Alpine White BMW M2
2018 M2  [0.00]
1500 - flawless as well.
      10-06-2018, 06:21 AM   #7
randyt
randyt's Avatar
225
Drives: 2018 MGM 6MT M2
2018 BMW M2  [0.00]
~5,000mi - no issues like you describe.
As far as tire pressure goes, I check manually as I have found the values reported by the TPMS to be a little off from what I get for cold values.
Tiss'er78.50
      10-06-2018, 11:16 AM   #8
tux2005
234
Drives: 2017 M2
I think Canadian LCIs do not have TPMS, it will never tell you pressures or temps. It uses wheel rotation sensors for detecting flats.
I think only the Canadian M2Cs have started to have TPMS. Early runflat BMWs may have had TPMS but for the longest time we've not had TPMS in Canada, only the latest generations have started introducing TPMS (again?) to Canada.
m2
