Spacer size help for noob
08-23-2018, 10:47 PM | #1 |
147
Rep 796
I have a lci e92 x drive on kw v1, wheels are 18x9.5 tires are 255/35/18 in the rear. I calculated about an inch or so to hit the fender, will i be ok to run 18mm or 20mm? (Dont mind rolling the fender)
08-24-2018, 02:42 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Just measure it, then you can work it out yourself...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
