08-23-2018, 01:07 PM | #1 |
174
Rep 400
1/4 mile time M240 xdrive
I went to drag strip for the first time.
From the search, I knew that the 1/4 mile time should be around 12.5 sec. Car was in sports+ mode with transmission in sport auto. Used launch control every time. My best run was 12.39 sec at 109.4 mph which is very respectable and consistent. I did total of 9 run (7 runs almost back to back then 2 more runs after an hour) and time was so consistent. Best run was the 7th run. (worst was 4th run, 12.67 sec at 108.4 mph with manual shifting) Weather was around 80F at the beginning and went down to 70F at the end. Intake air temperature was between 120~135 F before the start, quickly dropped to 110F as the car moving. I was impressed how consistent this car ran. Trap speed was within 1 mph and time was within 0.15 sec (excluding the one I shifted manually) No heat soak issue. This consistency kinda made the drag race boring. Not much to do to improve the time. lol Last edited by TajoMan; 06-18-2019 at 08:27 AM.. Reason: adding a link |
08-23-2018, 04:43 PM | #3 |
174
Rep 400
100% stock. (well except Dinan mid pipe which adds nothing but noise.)
I don't have moon roof, so it's 30~40 lb lighter but I'm not a small driver at 200 lb. lol |
08-24-2018, 04:02 PM | #5 |
174
Rep 400
I kinda wished if I could adjust the launch rpm.
In terms of grip, this awd can use higher launch rpm for sure. (don't know about reliability though. lol) |
08-24-2018, 08:36 PM | #6 |
1165
Rep 1,931
2 gal of race fuel or e85 would be interesting to see.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
08-29-2018, 01:45 PM | #8 |
140
Rep 181
Drives: 2023 M340xi Portimao Blue
Great times. 💪
Now the fun will be modding and seeing how much quicker she gets each time. |
08-29-2018, 04:32 PM | #9 |
174
Rep 400
08-29-2018, 04:34 PM | #10 |
5493
Rep 5,339
Are people running a light ethanol mix in otherwise stock N55s and B58s with no issues?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
08-29-2018, 04:35 PM | #11 |
5493
Rep 5,339
Nice runs and yep, AWD and auto makes all the difference. Basically like running slicks plus with the auto, you can build boost on the launch. Something you can't do with a 6MT. 1.7-1.8 60 foot. Man....
08-29-2018, 04:42 PM | #12 | |
174
Rep 400
The slowest run was the one that I shifted manually. (It was still 12.67 sec) Even more impressive was how reliable it was. I ran back to back 4~5 runs without much waiting, no issue. Waiting in line for 20~30 minutes with engine idle, no problem either. Times were within 0.15 sec from all of those runs. I don't know why some ppl complaint about heat soak. (Maybe it will be a problem at 100F+ ambient) |
08-29-2018, 11:20 PM | #13 |
806
Rep 1,367
Nice. My best last year was also 12.39, but that was with JB4 on the old Map 1 and a 1.98 60'. I'm RWD though. Your time/trap are stout for a bone stock car. Heat soak is worse with a piggy back. Do a DP and Stage 2 Mission flash and you'll be running 11.70's with ease!
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
