BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Suspension noise from camber plates and endlinks
      08-17-2018, 11:32 PM   #1
BMSE92_Harry
73
Drives: 08 335i coupe
Anyone else with BC racing or Sonic Tuning coilovers have squeaking noise from
the camber plates that they provided? I’ve had mine for about 2 years now, and they squeak occasionally when I go over small bump.
Anyone else have this issue? Should I go back to stock top hats?
I installed the hotchkis endlinks in front when I lowered my car, lately I noticed some clunking noise when I’m backing out of the driveway, I wonder if the boot on the end links are worn.
Anyone else got any recommendation?
      08-18-2018, 07:25 AM   #2
Rob09msport
128
Drives: 09 335 msport
Teflon spray camber plates and grease end links and away bar bushings
      08-19-2018, 11:46 PM   #3
BMSE92_Harry
73
I will try it out. Thanks for the recommendation
      08-23-2018, 12:52 AM   #4
BMSE92_Harry
73
Tried the Teflon spray on the camber plates, didn’t hel at all.
Removed the end links and found the top ball joints boot are worn. Going to order new ones.
      08-23-2018, 07:11 AM   #5
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
Tighten the top hat bolt on the front coils. Mine were squeaking after about 2 weeks of use until I tightened them.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      08-23-2018, 01:34 PM   #6
Rob09msport
128
Did you tighten to 35 lb or just use impact I was told 18lb on camber plates and 35 on strut and no Impact for fear ruining seals but every mechanic I know uses impact despite this
