08-15-2018, 12:31 AM | #1 |
69
Rep 65
First track day done in the M2, some driving questions
Hi all,
Just had my first track day on Saturday just gone. My car is stock, but I switched out pads to Pagid RS29 for the day after heeding advice of many on this forum, and glad I did. I'm going to switch them back out for the stock pads for daily driving, as I find the squeal and clunking sounds to be a little intense for day to day driving. Just had a few questions for those more veteran to driving on track in this car, specifically for DCT users: -Are you guys using MDM or DSC off? I left MDM on for this day, seemed to work fine, would only see TC kick in out of some corners. I imagine DSC off is better once more experience is had though. -For manual shifting, at what RPM are you mostly shifting up, or shifting down? -When braking from a long straight (high speed heavy braking), when do you start to shift down? I seemed to struggle with the timing of shifting down in braking, I seemed to do it too early and force engine braking, which I didn't really want to do. Thanks guys! |
08-15-2018, 06:59 AM | #2 |
Life is on the Track, the rest is just waiting.
381
Rep 731
My experiences on the track with 6 MT is that I usually shift with sound of engine when shifting up. When downshifting on corners, brake, trail brake, then downshift, ease on power.
08-15-2018, 07:13 AM | #3 |
2785
Rep 3,681
If you’re comfortable with the car, DSC off. You’ll find it more rewarding and that the car is actually easy to drive at the limit with DSC off.
On a stock car you can gain a little time if you shift around 6-6.5k, when you start to feel the car lose power in the upper RPMs. If you’re engine braking while downshifting, you’re either not braking hard enough or downshifting early. My advice is to run DSC off, keep the car in auto mode, get a good instructor, learn the limits of the car, pay attention to how the car is shifting, and then try shifting manually. There’s much more time to be gained learning the car and driving at the limit, vs manual shifting the DCT. The car does a better job with shifting with DSC off, too. |
08-15-2018, 07:40 AM | #4 | |
633
Rep 650
08-16-2018, 07:13 PM | #5 |
69
Rep 65
Thanks for the advice!
I think I would be comfortable with DSC off, I was running MDM for the day mostly because it was wet, and I hadn't driven on track in the wet before. I'll take it onboard and try your suggestions for the next track day. Had another thought - if I switch back to my street pads, is there anything I need to do when I switch? Is it required to bed in the street pads again? Thanks! |
08-16-2018, 07:38 PM | #6 | |
2785
Rep 3,681
Try some PFC 08s or 11s next time. You’ll like them more and no bedding required. |
08-16-2018, 07:47 PM | #7 |
85
Rep 133
Drives: M2, D5
For folks who coded Euro MDM, what did you use to do it?
08-16-2018, 07:52 PM | #8 |
2785
Rep 3,681
Okee at www.codemycar.com. He’s great. He’ll code everything you want for one price.
Might as well go M4 GTS MDM if you go that route. Less restrictive than Euro MDM. |
norberts84.50 |
08-16-2018, 10:30 PM | #9 | |
69
Rep 65
Also assuming after my stint back in the street pads, once I go back to the track pads for a track day (maybe in a month or so), I need to re-bed in correct? |
08-17-2018, 07:33 AM | #10 | |
2785
Rep 3,681
Personally, I really dislike Pagid. Compared to PFC, the braking feel is worse, they don’t hold up as well under high heat, and they require more bed in when switching bn track and street pads. |
08-17-2018, 10:06 PM | #11 | |
69
Rep 65
Just a thought I had looking at the rotors last night, there's a crap tonne of rust in the middle section between the contact parts, is there normal with everyones? |
08-20-2018, 12:01 PM | #12 | |
319
Rep 660
