Wiring bracket clip mount damage, come on!
08-06-2018, 10:06 PM | #1 |
Rep 76
So I discovered that my wiring bracket that runs horizontal at the rear of the hood seal isn't damaged, it is the doggone locking triangles on the firewall that are. Yep, bought another bracket and no-go, then I realized the metal was broken. I have yet to understand why so-called engineers design this way.
Any suggestions on an easy repair or am I stuck with it marring the top of my intake? 09 328i
if you didn't have fun, it wasn't difficult enough.
08-06-2018, 10:56 PM | #2 |
225
Rep 807
Drives: 2011 335is 6MT
Do you mean the clips that hold the harness duct to the cowl?
If so, the clips should be on the cowl 64316924277 |
08-07-2018, 02:09 PM | #3 |
17315
Rep 18,737
Let's get some nomeclature straight first. There is a wiring harness case (cable tray) that clips into the lower cabin air filter tray. The lower cabin air filter tray is what most people call a "cowling"; it's the tray that sits in front of the windshield and holds the cabin air filter. It is removed by releasing the cable tray, the two (2) 8mm bolts at the sides near the fenders.
The cable tray holds a thick red wire which is the (+) battery cable. It slides and snaps into the lower cabin air filter tray. All of it is plastic, not metal. If the plastic clips on the cable tray break, or the female side breaks on the lower cabin air filter tray, you can drill holes through the cabin air filter tray and use course-thread automotive screws to hold the cable tray in place. Or get all new parts... |
Psyphertext7.00 |
08-07-2018, 07:55 PM | #5 |
Rep 76
Under the lip. There were several metal arrows that the bracket clips to that are partially broken. These appear to be permanent fixtures in this location.
08-07-2018, 07:56 PM | #6 | |
Rep 76
08-07-2018, 10:43 PM | #7 | |
225
Rep 807
https://www.ecstuning.com/b-genuine-...BoC5pUQAvD_BwE This is the lower cabin air filter tray from efthreeoh's post. Eight screws with 8mm hex heads are all that hold it and the upper in. Last edited by GATORB8; 08-07-2018 at 10:49 PM.. |
Psyphertext7.00 |
08-07-2018, 10:52 PM | #8 |
225
Rep 807
Diagram here:
https://www.realoem.com/bmw/enUS/sho...28#64316924277 |
Psyphertext7.00 |
08-08-2018, 05:51 AM | #9 | |
17315
Rep 18,737
You keep referring to metal; there are no metal parts of the components, they are completely made of various plastics. The cabin air filter tray is a fiber reinforced plastic, which is very hard. The cable tray is some type of polyvinyl/polystyrene or perhaps ABS injection molded plastic.
Psyphertext7.00 |
08-08-2018, 05:00 PM | #10 | ||
Rep 76
