Those who DIY tranny or diff oil change - What pump you used?
08-02-2018, 08:35 PM | #1 |
2670
Rep 6,301
Which type of pump did you use? I'm thinking of either buying a drill pump or the ones that you push on to pump like a soap dispenser.
08-03-2018, 08:18 AM | #2 |
623
Rep 3,198
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-03-2018, 02:42 PM | #4 |
Run Deep
15129
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [0.00] |
I used this:
https://www.walmart.com/ip/Custom-Ac...&wl13=&veh=sem The main reason being that it was cheap and simple and it worked. Did it take a while, yep. But I figured I would only have to do it once every 3 years or so, so the world wasn't going to end. As those mentioned above, though - if you don't mind spending the extra dollars, there are obviously better choices. |
08-03-2018, 02:59 PM | #6 | |
2670
Rep 6,301
Wanted a type like this but I read alot of bad reviews on it, I don't want to be stuck with no pump when doing the job and hence no car to go to the store right. |
08-03-2018, 03:00 PM | #7 |
2670
Rep 6,301
08-03-2018, 03:53 PM | #8 |
Run Deep
15129
Rep 4,123
FWIW, I changed the diff and tranny fluid on my old 2004 Miata several times with my old walmart pump before getting the BMW. It still works, all these years later. Cost me like $6.
08-03-2018, 04:12 PM | #9 |
2124
Rep 2,758
Ditto, I have had the same one(similar to the one in the walmart link) for atleast 10 years. Have used it A LOT of times and no issues still.
Run Silent15129.00 |
08-03-2018, 04:50 PM | #10 | ||
2670
Rep 6,301
Ok well thanks guys, I'll check out the USA Walmart and probably grab that one when I go pick up my FCP euro parts down south. |
08-04-2018, 02:08 PM | #11 |
17367
Rep 18,769
I'm ancient... so I have a lot of tools. I've tried most of the products listed. I have to say the best device I've used to pump oil into a transmission or diff is an automotive fluid syringe. It pulls the oil out of the oil bottle and then pushes it into the trans/diff. I have one I bought probably 38 years ago (so its made in the USA out of metal), but it works the best. Here's a link to a modern-day version.
https://www.oreillyauto.com/detail/b.../51884/4753862 Here's a metal one from Advanced Auto: https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
08-04-2018, 02:17 PM | #12 | |
17367
Rep 18,769
All that said, I did recently get a Motive fluid pump. I've used it once. It's a bit too big for a few quarts of fluid IMO.
