Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Noisy Hawk HPS 5.0
      08-02-2018, 12:04 PM   #1
limpiabota809
limpiabota809's Avatar
16
Drives: e46
Noisy Hawk HPS 5.0
Whats up guys wanted to see what you guys think of my current situation.
I swapped pads and rotors all around, I used R1 concept drilled and slotted rotors with Hawk HPS 5.0 pads. First I must say I am happy with the performance of my setup and the very minimal brake dust I see but they get pretty noisy which is what Hawk specifically says they dont do. I did break them in correctly as well.
The noise comes on once the pads get hot but what I find the strangest is that it doesn't make noise every time I apply the brake it is intermittent.
An Indy told me that I would have to live with the noise as thats just how they are or get different pads.
Any thoughts?
@limpiabota_e46
03 330XI - FK Coils, AFE Stage 1 CAI, EU2 Tune, Headers, Straight Pipes, Mtech 2 Front w/molded Aqray Lip, Mtech 2 rear, CSL Style Trunk, GTR Style Hood
      08-02-2018, 02:10 PM   #2
upshift_downshift
upshift_downshift's Avatar
40
Drives: BSM 07 E90 335i
Any thoughts?
Try contacting Hawk and let them know what's going on. They do have a warranty.
      08-03-2018, 11:17 AM   #3
FCobra94
Guest
n/a
Drives:
Where are you getting noise? Front only? Rear only? Both?
      08-07-2018, 02:05 PM   #4
limpiabota809
16
Drives: e46
front only, im going to be doing coilovers and some steering work soon and when I do ill grease up behind the pads and change up the hardware. I will report back.
@limpiabota_e46
      08-08-2018, 01:36 PM   #5
SpartaEvolution
SpartaEvolution's Avatar
178
Drives: E46 M3, E39 M5, E36 328racecar
Did you apply the supplied grease to the back of the pads and edges where the contact the calipers? That is a common cause of high-frequency squealing.
      08-08-2018, 01:41 PM   #6
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
+1
I've had Hawk HPS, 5.0 and HP+ the only ones that make noise are HP+ and that was only at slow speeds and typically when they were cold (normal for HP+).
      08-08-2018, 08:11 PM   #7
limpiabota809
16
Drives: e46
Thanks for the heads up, behind the pad no that is my next thing to do when the coilovers are getting done.
@limpiabota_e46
      08-10-2018, 10:23 AM   #8
SpartaEvolution
178
If you can't find the little grease packet, you can also use 'disc brake quiet' which should be available at any parts store.
