BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > 100K Change Shocks?
      08-02-2018, 01:53 AM   #1
as400
as400's Avatar
16
Drives: E92 325d
100K Change Shocks?
Car has just ticked over 100K this is a 2009 E92 325d Highline though I lowered it with Eibach springs but left standard shock absorbers on.
Going over potholes and speed bumps now doesn't feel as nice as in a new car...is the answer to replace the shock absorbers all round?....are there any other bits that would benefit from being done at the same time?...I keep hearing polyurethane bushes but don't know what they are!
      08-02-2018, 02:38 AM   #2
e92_bryan
127
Drives: ‘11 e92 328
Well putting on aftermarket springs will shorten oem shock’s life
Just go with coilovers
      08-02-2018, 07:24 AM   #3
feuer
feuer's Avatar
4276
Drives: wife crazy!
At 100k struts and shocks have been blown already for a while especially because you had lowering springs. That makes other parts work extra. At minimum you need to replace strut and shock mounts.
Appreciate 3
      08-02-2018, 10:50 AM   #4
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
2214
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Stick Bilstein/Koni shocks in there. Their damping rate will line up with the Eibach's spring rates and bring back that comfortable ride.
Also do strut/upper/lower shock mounts too.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      08-04-2018, 09:28 AM   #5
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
The Bilstein B8's are perfectly tuned to the springs you put in. However, B8's are extremely difficult to source in the US, as of right now. In a month, who knows.
If you buy them on eBay in Europe, you can get them.
Otherwise, your next choice is Koni yellows.
If you lower the car, you will need adjustable swaybar links. You add about 1.25" in the length of the front & subtract 1" on the rear links.
I would replace all the surrounding hardware in addition to the shocks & struts (strut bearings, bump stops, spring mounts etc....).
      08-08-2018, 06:14 AM   #6
Badorl
Badorl's Avatar
Drives: BMW E3 1970
If you want an upgrade, get the FatCat Motorsports bumpstops and some Rancho boots. Better on the bumps than stock. As noted above, KYB AGX's can be had for less than $300 on eBay. That's what I did and haven't had a problem. Having the adjustable knob makes them much more versatile. Otherwise the KYB GR2's are ok from what I've read.
As an aside, since you'll have the wheels off anyway, you could replace the brake pads.
Shocks will make the biggest difference by far. If you're money is tight I'd just do shocks and boots and leave it at that.
      08-09-2018, 04:17 PM   #7
feuer
feuer's Avatar
4276
Drives: wife crazy!
Do you have a link? I would like to get some KYB AGX for my e90
whyzee1251678.50
