07-30-2018, 03:31 PM | #1 |
206
Rep 349
Disable auto shift down in Manual shifting mode
In iDrive, Is there a way to disable shifting down automatically? Or at least disable first gear so it gets shifted to 2 at stop?
Thanks |
07-30-2018, 04:45 PM | #4 |
30
Rep 41
Funny enough, I was just thinking about the same thing this weekend. I absolutely hate first gear on the ZF8. It's completely useless for me. At the strip I was noticeably quicker (.2) in the 1/4 mile by starting in 2nd and on the street it's so much smoother to start in 2nd.
Ultimately, it's not the ratio, but the programming or maybe the stall rate? The ZF8 is smooth as can be in all but first gear. It's really hurky jerky for me and the shift from 1st => 2nd is always a crapshoot of really smooth to snap your head back when just slowly accelerating. I'd love to find a away to just have it downshift only to second and ignore 1st unless specially called upon. I know that won't happen, of course, but it'd be nice. |
koston37.00 |
07-30-2018, 05:38 PM | #5 |
206
Rep 349
Strain the transmission? I understand automatically downshifting but Unless you are drag racing up Burj Khalifa what’s the point of 1st gear?
07-30-2018, 08:30 PM | #6 |
Luxury at the redline :)
9105
Rep 7,563
When I had a loaner car in 2010, I used to be able to rev-up to 3000RPM in neutral, drop into drive (1st gear) and burn out massively.. The car would allow it.
Fast forward to a 2011 loaner, tried the same trick and the computer would not allow me into any drive gear until the RPM drop back down to 0. They apparently added an electronic lockout for 1st gear at a higher RPM. Point being, BMW engineers write the software based on what they feel is appropriate for the drivetrain's longevity and efficiency. I assume don't allow you shift-down to 1st because the RPM is at a higher rotation, for whatever reason they feel is not appropriate. Possible to avoid a stalling motor. Last edited by Poochie; 07-30-2018 at 10:46 PM.. |
08-03-2018, 03:26 PM | #7 |
3850
Rep 2,874
After reading this I had to verify it, but at least on mine, you can put it into manual-mode and upshift to 2nd while stopped and start off from 2nd. DK if that is what you meant, or if you want it to just act like there is no 1st when it downshifts for you?
08-03-2018, 06:40 PM | #8 | |
1404
Rep 5,262
But it's not possible |
Maynard3849.50 |
08-04-2018, 01:09 PM | #9 |
593
Rep 1,220
Drives: 2015 M235ix
This man needs an old-fashioned two-speed automatic Power-Glide transmission, last seen circa 1973. It's the excessive number of gears that makes 1st so troubling.
3.0L8944.00 |
08-04-2018, 08:47 PM | #10 | |
404
Rep 745
Drives: 2017 M240i Glacier Silver
Fun Cars (daily drivers) 2001-2016: 2001 Honda Prelude | 2016 - present: 2017 M240xi Glacier Silver Coupe
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible |
08-05-2018, 11:55 AM | #11 |
195
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
Well since last updating my car to I-level F20-18-07-531 and that jerkiness is gone. It’s silk smooth at the moment. The only way I can understand that it’s changing gear is by looking at the tachometer.
08-10-2018, 11:39 PM | #12 |
11
Rep 38
Why do you want silky smooth? I like the jerkiness - it makes the car feel meaner!
08-11-2018, 01:04 PM | #13 |
195
Rep 366
Drives: 218i Coupe
08-13-2018, 11:40 AM | #14 | |
30
Rep 41
08-13-2018, 11:44 AM | #15 |
30
Rep 41
I don't really need silky smooth, but first for me the engine is sometimes inconsistent with with the pedal. Like, I can apply 10-15% throttle and have the engine sort of go flat, then pick up then snap hard into second. This is just normal driving where I just want to get to work or pick up dinner. It's only first. All the other gears are fine. I just feels like bad programming or incorrect stall speed or something.
