Inexpensive Brake Pads/Rotors for my E90 2006 325i
07-28-2018, 03:11 PM | #1 |
Rep 14
Hi all,
I need to replace the Brake Pads & Rotors for my E90 2006 325i. I am looking to sell/trade it very soon so I am looking for the most inexpensive options but still decent quality. Any recommendations?? Thank you. |
07-28-2018, 05:47 PM | #3 | |
Rep 14
Do you recommend any particular Centric pads/rotors? They have quite a selection including something called Axle Packs. |
07-29-2018, 06:56 AM | #4 |
97
Rep 399
Drives: 2023 BMW i4 eDrive40
Rockauto for Brake pads and rotors
Cali,
Go to “rockauto.com” for the best prices on auto parts. I ave the Centric rotors on my 2006 325xi and am pleased. I suggest using the Centic semi metallic pads to match up to what the vehicle had originally. Wallyf |
tlow982188.00 |
07-29-2018, 07:26 AM | #5 |
1444
Rep 2,127
07-29-2018, 08:20 AM | #6 |
1903
Rep 6,968
Go with Zimmerman & Akebono pads. Hard to beat that combo. FCP has them & you get a lifetime warranty
07-29-2018, 09:05 AM | #7 |
17309
Rep 18,733
Is the pad replacement notification on? If not, why replace anything?
07-29-2018, 10:35 AM | #8 |
Crazy Frog
543
Rep 1,211
Yep, RockAuto is the absolute cheapest. I got 4 new rotors and front pads. Front centric rotors were $22 each, rear rotors were $18.22 each. Front pads Centric CTek Metallic were only $12.
The only thing with RockAuto is you need to bundle your items together so they ship from the same location. RockAuto dropships from many different suppliers. Sometimes you might have to select a slightly more expensive item because it ships from the same location as the parts already in your cart so you save on shipping costs.
07-29-2018, 10:40 AM | #9 |
Crazy Frog
543
Rep 1,211
Also go check out Pentosin 5w-30 BMW LL01 oil at RockAuto it's super cheap there. $25 for 5 liter jug and $6 for 1 liter bottles.
Compare that to FCPEuro...$40 for 5 liter jug and $10 for 1 liter jugs. FCPEuro is making a killing with those fat ass margins and FCPEuro doesn't even stock most of their inventory. They utilize a "just in time" inventory management system meaning they go out and buy it from their suppliers after they receive your order.
07-29-2018, 07:53 PM | #11 |
Rep 14
Can I ask which ones you ordered & for what vehicle and how have they worked out for you.
07-29-2018, 08:11 PM | #12 |
Is it the shoes!?
3884
Rep 5,112
07-29-2018, 10:37 PM | #14 |
Rep 14
So from RockAuto it looks like the choices are:
Rotors: CENTRIC*12134078*C-TEK Rear $21.79 CENTRIC*12134077*C-TEK Front $24.79 Or CENTRIC*32034078*GCX Brake Rotors by StopTech Rear $27.79 CENTRIC*32034077*GCX Brake Rotors by StopTech Front $30.99 Pads: CENTRIC*30012670*Semi-Met Pads w/Shim and Hardware Rear $13.45 CENTRIC*30010610*Semi-Met Pads w/Shim and Hardware*Front $20.79 Or CENTRIC*10512670*Posi-Quiet Ceramic w/Shims and Hardware Rear $24.79 CENTRIC*10510610*Posi-Quiet Ceramic w/Shims and Hardware Front $44.99 It looks like a few people have said go with the lowest price pads & rotors which would be the CENTRIC*C-TEK rotors with CENTRIC*Semi-Met Pads.........Agreed? As I said I am not keeping the car beyyond a few months. |
07-30-2018, 12:20 AM | #15 | |
Crazy Frog
543
Rep 1,211
View post on imgur.com This is for 2011 E90 328i. Be careful and confirm part numbers on the rear rotors because sedans and coupes use slightly different rear rotors. Coupe rear rotors will fit on sedan rear but the hand brake will not work because the "hat" on the coupe rotors is slightly larger than the "hat" on sedan rear rotors. Front rotors should fit both.
07-30-2018, 01:28 AM | #16 |
2188
Rep 5,002
I've been super pleased with Centric 'Premium' or 'High Carbon' as they have the black E-coat which keeps your rotors from looking like a rusty eyesore. They are minimum double the price @ $45ish rear and $58 front vs the E-tek, however.
Also, my semi metallic centric pads do squeal a tad and others on here have had similar results. For that reason I'd suggest either the Centric ceramic (little less bite and no dust) or the OE 2010+ BMW pads as they dust less, have great feel and don't squeal. I'm pretty bothered by the noise, so take that for what it's worth. I'm generally of the mindset that if they aren't trackpads I shouldn't be hearing them. YMMV Last edited by tlow98; 07-30-2018 at 01:35 AM.. |
07-30-2018, 03:19 AM | #17 | |
145
Rep 334
JP
07-30-2018, 12:58 PM | #18 |
2188
Rep 5,002
07-30-2018, 01:24 PM | #19 |
145
Rep 334
This is my reply directly to you. Autozone is your quickest option. If your willing to wait I would eBay ceramic pads off there.
JP
07-30-2018, 02:34 PM | #20 |
35
Rep 263
Don't forget the 5% off promo code at rockauto!
E90 330i | M-Sport Conversion | Apex ARC-8 18X9/9.5 | General AS-05 Tires | Koni Str.t / H&R Sport Kit | Centric Carbon Rotors | Akebono Ceramic Pads
E82 135i | M-Sport | BMS DCI | BMS Phx Racing CP | MHI OEM Twins | Ebay OCC | Silicone VL | G-Plus 5" FMIC | Alzor Style 040 18X8/9 | Barum Bravuris 3HM Tires |
07-30-2018, 03:08 PM | #21 |
Rep 14
07-30-2018, 03:13 PM | #22 | |
2188
Rep 5,002
Cheap and Fast are certainly attributes that products can be judged upon, but they’re not what I’m concerned with. It’s possible the OP might be interested in these options tho. To each their own. Last edited by tlow98; 07-30-2018 at 04:37 PM.. |
