Oil pan leak...simple fix?
07-26-2018, 07:02 PM | #1 |
44
Rep 220
For a very minor leak I suggest a simple fix as follows:
1. Drain oil pan via regular oil change. 2. Remove each pan bolt separately and replace with new bolt to torque spec. Your opinion? Mikey |
07-26-2018, 08:09 PM | #4 |
263
Rep 620
Drives: E90 335XI MSport, S2000
07-26-2018, 08:15 PM | #7 |
1903
Rep 6,968
I have only heard of re-torquing the existing bolts. Most of the time, this doesn't really work, or if it does it's a temporary fix. Especially if the oil pan gasket is original to the car and over 125,000 miles old.
07-26-2018, 08:49 PM | #8 |
1044
Rep 1,667
My experience with gasket maker is that it won’t stop a leak by applying it from the outside...it needs to be applied to the sealing surfaces...
Efthreeoh17315.00 |
07-26-2018, 08:51 PM | #9 |
263
Rep 620
Right. i'm not sure if the pan can be lowered just a half of an inch or something in vehicle. I don't know, I'm not a doctor.
07-26-2018, 08:54 PM | #10 |
263
Rep 620
07-26-2018, 09:46 PM | #11 |
17315
Rep 18,737
Listen, the pan seal design is a POS. The sealing material gets hard and brittle over time. Re-torquing the bolts, or installing new bolts (they install to 8 nm IIRC) will not help; the seal has no compression left once it gets brittle. If it's leaking, a new gasket is required with additional gasket sealer. No other way around it.
07-26-2018, 09:51 PM | #12 | |
17315
Rep 18,737
The fastest and easiest way to cure a leaking pan gasket is to just drop the subframe. Not dropping the subframe and trying to fuck around with it will take far longer. Follow the DIY, it's one of the best DIYs published for the E9X.
