Rear Brake Dust Shield
07-26-2018, 05:17 PM | #1 |
1903
Rep 6,968
My rear brake dust shields keep rattling against the rotors at low speeds. Drives me nuts. I pry/push them away from the rotors, and they just curl back towards the rotors after about a week. I know it's not a good idea to just cut them off since the shield does keep the heat from the brakes away from the control arm bushings, and it keeps excess crap away from the rotors.
I "think" you have to be doing a rear wheel bearing DIY, in order to access the bolts that hold them on to the Hub. When I did my rear brakes in April I tried to take them off when the rotors were off. I took the drum emergency brakes off. There was 2-3 small bolts that seemingly held on the dust shield, but when I took them off, and tried to take the old dust shield off it wouldn't budge. So, I got the impression that there were bolts behind that the hub was covering up. I have 2 new rear brake shields. Am I correct ? |
07-26-2018, 06:49 PM | #2 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
07-27-2018, 08:25 AM | #4 |
1903
Rep 6,968
You can see 4 holes where I think bolts must go through. The two smaller ones are where the two bolts exist from the emergency brake side, once you remove the shoes & what not. It looks like it is semi-pressed on due to the tabs in the middle. My guess is that you would have to take the hub off, in order to take the brake dusts shield off
My wheel bearings on all 4 wheels are original with 153,000 miles "knock on wood". Don't ask. I don't know how or why they they have lasted this long given crappy Michigan roads, salt used on them in the winter and Midwest weather. I seriously think we have more dirt roads, in this state, than anywhere in the country. I am not complaining or anything about how good or well my wheel bearings have held up. Trust me, I am not looking forward to the day I have to change the rear wheel bearings out. So, I guess I either wait till a wheel bearing goes in the rear or just cut them off with tin snips or a dremmel maybe. : |
07-27-2018, 09:03 AM | #5 |
Sua Sponte
1299
Rep 2,850
Like I said, a LOT more work to replace them than remove them.
04-26-2021, 01:29 PM | #6 |
13
Rep 105
One of my brake dust shields has also come loose and makes an irritating grinding sound as the car moves.
So just how big a deal is it to replace it? Something that Firestone can do with modest expense? Can be done without removing the bearings? Or it is just better to tear it out without replacement? |
05-19-2021, 01:23 PM | #7 | |
1444
Rep 2,127
This is the first car I encountered where they are bolted onto the hub carrier BEHIND the wheel bearing assembly. Totally stupid design. So, yes, removing the wheel hub is the required official procedure. I want to keep mine, so this drives me nuts! Working on the rear suspension refresh and finding all these little things that will nickle and dime me until I realize I should've just bought a used complete subframe dropout from a Southern car and swap it in a day and be done. |
05-19-2021, 07:42 PM | #8 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Put it this way, while I was doing the job I stuck it out for those 2 tiny pesky little rear brake lines for example. But said fuck no to the rear brake dust shield after looking at it for 5min, rare for me to do that. Just trim it off and call it a day
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
11-26-2022, 03:55 PM | #9 |
12
Rep 92
I’m in the same boat. replacing bearings and hubs. RH dust shield is solidly attached while Lh is loose and rattling.
In front of the dust shield is the parking brake backing plate, so I removed the parking brake shoes and Hardware, then 10mm bolts (x2) and larger 16mm (but super short) bolts (x2). But the dust shield and backing plate will not budge. Is it matter of force to get them off? In general the suspension and brakes are very rusty. I realize the hub has to come off to get them off but I can’t even get them to loosen from attached position. Last edited by pbedrosi; 11-26-2022 at 03:57 PM.. Reason: Bramer, spelling |
12-30-2022, 12:36 PM | #10 |
Rep 6
Did you ever figure this out? I’m in the same boat. Different reason though. One of the bolts that screws into control arm is stuck broken in the hub and won’t budge. I’m going to have to find a replacement hub on eBay but the ones I’ve seen come without a dust shield. I have the hub off the car but other than removing the 10mm and 15mm bolts I can’t figure out how to remove the whole shield for re-use.
01-03-2023, 05:05 PM | #11 |
12
Rep 92
I did figure it out. It’s friction fit. I placed a screwdriver between the shield and hub from behind and gave it a tap with a hammer.
I’m just dealing with other bolts that are rusted to continue my brake/hub/bearing replacement I’m shocked at how rusty the subframe and suspension components are, looks like a 20 year old Chevy lumina underneath Last edited by pbedrosi; 01-03-2023 at 05:06 PM.. Reason: Spelling |
