BMW M2 Forum > Regional Forums > AUSTRALIA > M2 to Chip, or not to Chip?
      07-26-2018, 05:49 AM   #1
lockwood
Drives: m2 lci
I've had a quote from Evolve Technik to 'chip' my DCT M2, at a cost of $1925.
Specs from them show an increase of 22kw and 80Nm torque around 3,300 rpm
Has anyone had this done? If so, was there a noticeable difference? Would you do it again?
      07-26-2018, 06:18 AM   #2
bwhouse
136
Drives: BSM M2C
I am no expert as I have been out of the BMW game for a few years, but based on my limited research for my upcoming M2C bootmod3 seems to be the best bet in terms of a tune with the added benefit of being able to flash the tune yourself.
      07-26-2018, 06:41 AM   #3
atlas
Australia
381
Drives: F10 535i, M2 LCI, G05 X5 40i
I just installed bootmod3 on my M2. Easy as, and can be done either via PC or your phone.
Heaps of user customisation available, and the tune feels great.
      07-27-2018, 01:19 PM   #4
den525
185
Drives: BMW M235i
You definitely notice the difference... but it's not much as the M2 has a higher spec'd tune from factory for the N55... hence the increase is only 22kw... while the M135 and M235 with the same engine gained a lot more as it's basically the same engine.
Had my M235i tuned a few years back.. stock 240kw (dyno'd 210kw atw) and after a flash tune it dyno'd 267kw atw)... while my mate's M2 stock 272kw (dyno'd 235kw) after the tune it dyno'd 270kw atw... same dyno but different year...
I drove his before and after and yes you can still tell the difference
      08-12-2018, 09:25 AM   #5
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
+1 on Pro Tuning Freaks BM3 tune. I have done it in my OG M2...totally "wakes up" the car. I'm in Canada so our currency is similar value to yours and it costs under $1k. You can start with OTS (off the shelf) map and then hit up one of the "tuners" listed in the app to get a custom tune specific to your mods and gasoline. Really great product and it offers a lot of customization if you are willing to do a bit of research and play around with it. N55 is pretty tapped out in M2 without changing some of the components (DP, FMIC, etc.) but you can def get more out of it if you go the FBO route and use the stg 2 maps.
      08-22-2018, 08:08 AM   #6
Tricki
Tricki's Avatar
Australia
215
Drives: BMW M2 Comp
Currently running MHD stage2+ 102 octane map with 3.5-4.0 litres E85 per tank. Logs Look great and car feels strong
Times from 100-200 have come down from 11.5 to 9.4 seconds and make it faster than the stock M2 Competition.
Below is a log of a run and MHD only costs around $600. You can reverse anytime you like and change diffeeent maps and aggression of burble if you want.
It's a must for this car,
https://datazap.me/u/mattspies/log-1...38;zoom=39-183
      11-23-2018, 04:48 PM   #7
asmotorsport
https://www.facebook.com/asmotorsport.cojm.au/
Australia
Drives: F87 M2 & E82 135i MSport
I have also hear good things about MHD Tune and intend to go with it when I get my 2017 home. I am about to fly to Sydney and then drive my 2017 F87 M2 back to PERTH.
Hey, Can anyone tell me if it will have a tool kit. I assume there is no spare wheel or jack, even with the Michellin Sports?
      11-23-2018, 08:04 PM   #8
SUB-ZERO
SUB-ZERO's Avatar
294
Drives: 2018 M2 + Spur, DB11, F12, X5
BM3
Search this Thread:
Advanced Search
m2
