What else (problem wise) to look forward to?
07-23-2018, 04:36 PM | #1 |
21
Rep 287
Hi everyone,
Need some advice from you. Bought 2011 335d with 59k miles back in March 2017 from dealership, was a previous CPO car (but CPO was disabled on it?) anyway, I didn't have the CPO coverage but the carbon build up cleaning was done under CPO around 55k miles so that put my mind at ease. Last January at around 70k miles, got a check engine light and P02CE code, which was diagnosed by the dealership to be a faulty injector #2 and replaced free of charge to me, after I paid $330 for a software upgrade (they couldn't run the diagnostics that was required by BMW to cover the part unless they did a software upgrade, which I had to pay for! kind of pissed me off, but ... lets move on.) I have done the oil/filter/cabin filter/air filter/exhaust fluid myself and all look great now. General maintenance stuff. A couple of weeks ago battery died on me and had to change the battery (used AAA battery truck and AGM battery from them) which just got registered to the car at the dealership so it should be all set. The car runs fantastic and with all the options it has, it is just a joy to drive. No plans on doing any mods that can cause issues with the CA emissions regulations. Had the crank shaft pulley / harmonic balancer go out on me this past week (other thread) and got that replaced by the dealer at a huge cost to me. $1450 or so out of pocket, as per other thread I should have been able to get it done cheaper but circumstances forced me to get it done ASAP and had to pay higher price for it. So be it. My question is are there any other items that will come up that I have to look out for as known issues on these engines? I am not worried about window regulators or brake jobs or other regular maintenance items.... but this balancer issue, just driving down with no warning and all of a sudden bam, crankshaft pulley and stranded and $1500 in repairs, this got me upset and am ready to sell the car now. Believe me, I am no stranger to BMWs and cost of maintaining them, (see my signature for the list of previously owned BMWs), but I am now wondering are there any other ticking bombs that I should look into before they show up? I really like the car and would love to keep it, but with kids and busy schedule, I have to decide if the mechanical interruptions are going to be often and ahead of me,..... or perhaps the worst of it is behind me already so it would be stupid to sell it now? What are your thoughts?
-Faz
2023 X5 x40i M-Sport 2018 330i F30 (Previous: 2011 E90 335d , 2017 F15 X5 x35i , 2011 F10 535i 6spd, 2011 E70 X5 x35i, 2007 E90 328i, 2005 E53 X5 3.0i, ) Last edited by faz; 07-23-2018 at 04:42 PM.. |
07-23-2018, 04:48 PM | #2 |
2127
Rep 3,368
Vacuum lines, intercooler boost hose o-rings and/or red boost pipe failure, cracked egr cooler (used spares are cheap), scr system issues (probably under 10 yr/120K extended warranty), turbo actuators/solenoids. I'm probably missing something, but those come to mind.
07-23-2018, 06:53 PM | #3 |
765
Rep 3,558
Faz, people have had fun with the urea metering valve, the temp sensor in the urea tank, same said tank leaking urea, and the NOX sensors related to same urea/SCR system. I’m unsure of your appetite for deleting the ABCs. It is well publicized here about the harmonic dampener going out. Never heard a price as high as $1450 for a replacement. Sorry to hear they got you good.
Lots of these headaches are gone with deletes but not pushing the issue. Some don’t want to do it because they want the car to remain compliant and others can’t delete because of their state’s laws. |
07-23-2018, 10:50 PM | #4 |
157
Rep 716
There are few case where the return spring of valve on the EGR cooler break. You have to replace the whole EGR cooler. You should put some grease on the spring to avoid the rust and it breaking.
In RED is the location of the spring Also, the Glow Plug Controller is likely to fail |
07-24-2018, 02:53 AM | #5 | |
21
Rep 287
-Faz
2023 X5 x40i M-Sport 2018 330i F30 (Previous: 2011 E90 335d , 2017 F15 X5 x35i , 2011 F10 535i 6spd, 2011 E70 X5 x35i, 2007 E90 328i, 2005 E53 X5 3.0i, ) |
07-24-2018, 03:01 AM | #6 | |
21
Rep 287
Thank you for all the details. I certainly appreciate it. Will have to decide in the next couple of weeks if I am going to keep the car or not. I mean I love everything about it. Part of me says I should stick with it and hope for the best.
-Faz
07-24-2018, 03:03 AM | #7 | |
21
Rep 287
-Faz
07-24-2018, 08:43 AM | #8 |
107
Rep 202
The thermostat is another part that is also likely to fail (if it hasn't already.) They typically fail open and as a result keep the coolant temp low thus overworking the glow plug system. If the coolant temp is extremely low (under 75 deg C) the DPF will be prevented from performing regens.
The good news is that the thermostat is a cheap part ($70-ish) and is DIY-able. Check your coolant temp by accessing the hidden menu in the gauge cluster and verify that normal operating temps are around 88 deg C. If not, replace part. |
07-24-2018, 03:17 PM | #10 |
Rep 110
07-24-2018, 04:20 PM | #11 | |
21
Rep 287
-Faz
07-24-2018, 04:21 PM | #12 |
21
Rep 287
Sorry didn’t , I will search for it and go through it.
-Faz
07-24-2018, 04:26 PM | #13 |
21
Rep 287
Thank you. Yes CA emissions requirements need to be met for license plate renewals. Will be on the lookout for these if I end up keeping the car. Thanks.
-Faz
07-24-2018, 05:23 PM | #14 |
Rep 41
Can you elaborate on that please? What is the software upgrade? I just got a P02CE code as well and am looking at my options. Currently giving it the "Italian tune up" with a double dose of Diesel Kleen...
07-24-2018, 06:40 PM | #15 |
157
Rep 716
P02CE can be an injector problem or a CBU problem. Or it could be from an old version of the DME software. I suspect the diagnostic procedure call to bring the DME software to the latest version.
07-24-2018, 08:22 PM | #16 |
240
Rep 559
Drives: 2018 M5 / 2011 X5 35d
Dealership tried to pull that one on me also when I took my X5 for the FRM recall.. they where telling I had to pay the “programming fee” even if they had to replace the unit.. so I took it to a different dealership and they fixed everything free of charge.. as it should if a certain item is under recall.
07-24-2018, 08:24 PM | #17 | |
21
Rep 287
Took it to the dealership and they said they will have to run diagnostics on it (BMW requirement to see if it falls under warranty or not). To run diagnostics the version of car’s software had to be updated and they wasn’t covered. I had to pay $330 to bring the software up to date, then they ran diagnostics and it shows injector issue and was fixed under the warranty. On another forum ( search result in that code) showed one of the users had run the car WOT a few times on the freeway and that managed to unclog the injector ( or something to that extent) so I would recommend trying to do the Italian tuneup first. I didn’t particularly want a software update but had to spend the money on it. I would have preferred to have tried the WOT approach first at least, but I saw that afterwards.
-Faz
07-24-2018, 08:27 PM | #18 |
21
Rep 287
Yes correct.
-Faz
07-24-2018, 08:30 PM | #19 | |
21
Rep 287
-Faz
07-25-2018, 07:51 AM | #20 |
107
Rep 202
A sign that your thermostat isn't fully closing. If you let it go, you can definitely expect a burnt out glow plug controller in your future.
07-25-2018, 08:02 AM | #21 |
157
Rep 716
07-25-2018, 01:38 PM | #22 | |
21
Rep 287
For future reference and quick access for myself others that might come across this post, found the following: Thermostat DIY how-to here: https://www.e90post.com/forums/showthread.php?t=632656 Thermostat part number: 11517805811 ($80-ish) https://www.fcpeuro.com/products/bmw...5d-11517805811 https://www.ecstuning.com/b-genuine-...r/11517805811/ ===== Glow plug controller part no.: 12218591724 ($120-ish) https://www.fcpeuro.com/products/bmw...x5-12217800156 https://www.ecstuning.com/b-genuine-...e/12218591724/ Also a how-to video on glow plug controller change, in case that is needed in future:
-Faz
