New Battery Died after couple weeks?
07-19-2018, 05:02 AM | #1 |
56
Rep 291
I know I should do the battery registration but I haven't done it yet. The battery dies after couple weeks. Now I have to jump it after not driving the car for 2 days.
I read someone talking about battery died after 1 year without battery registration. I just figured I could swap it out since it comes with 3 year guarantee. Anyways, I don't know history about this car. When I bought it a month ago, it had cheap recycled battery so I just figured it had a bad battery. I am not sure it died because I didn't register it or it might have some parasite drain somewhere (no audio mods or anything) Maybe the car kept charging the battery when it was full and caused to go bad? Should I register it now and see how it goes or Replace with new one and register asap? |
07-19-2018, 12:01 PM | #2 |
1918
Rep 13,117
This is not the sub forum for battery questions which have
been quite hashed out . 1) If you don't drive the car enough the battery won't get charged. 2)If you switched battery types from lead acid to AGM or vice versa it can cause problems if you don't reprogram the car for battery type and size. 3) Did you match the amp hour size. 4)You could have a parasitic drain. 5) The alternator could be going bad. http://www.bimmerfest.com/forums/sho...15&postcount=6 Last edited by ctuna; 07-19-2018 at 12:06 PM.. |
07-19-2018, 03:05 PM | #3 | |
453
Rep 2,973
Regulator can be changed with the alternator on the car.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
07-19-2018, 11:34 PM | #4 | |
56
Rep 291
I doubt the Alternator is going bad. The battery was completely dead. I coudn't even unlock the door with a key fob. I drove around little bit, turned it off and it started normal which means Alternator charged the battery?
thanks for pointing out AGM battery. Maybe the car with AGM from the factory and it hasn't been coded yet. Quote:
