07-17-2018, 06:51 AM | #1 |
23
Rep 89
lightweight rear rotors - what options are there?
anyone running lightweight rear brake rotors in size 345x24mm ?
I'm having a hard time finding options out there, only found the ECSTuning ones. I believe OEM are 8.8kg each, something under 8kg would be awesome !
N20, EWG, Full M package, 19" x 8.5/9.5, JB4, Catless DP, Custom 3" exhaust, Upgrade intercooler with metal piping, drop in K&N, Snow Performance Stage 2 kit
07-19-2018, 06:02 AM | #2 |
23
Rep 89
bump
07-21-2018, 04:10 AM | #4 |
23
Rep 89
do you have a part number?
07-21-2018, 06:26 PM | #6 | |
8245
Rep 16,086
The weight reduction is in the hub. If the hub is aluminum it dissipates heat faster than cast iron. If the hub is steel it dissipates heat at about the same rate as cast iron.
07-23-2018, 08:00 AM | #7 |
23
Rep 89
not an issue as i dont track my bmw
less hub/wheel weight = more responsive and quicker car !
07-23-2018, 08:18 AM | #8 |
23
Rep 89
so far i found the following which is the same as OEM and both have aluminium hats:
ATE 24.0130-0233.2 (10.1kg each) ATE 24.0124-0250.2 (7.7kg each) I guess other ones with aluminium hats + drilled would be a bit lighter.....anyone got part numbers?
