07-14-2018, 01:59 PM | #1 |
5559
Rep 5,374
The most reliable and best fitting charge pipe at the TB and IC
So I'll likely be getting a charge pipe soon for my M235 RWD. I've researched all the charge pipes as there are many threads regarding them for the N55 F2x and F3x chassis, but I'm interested to hear from the owners regarding the fitment of the charge pipe at the throttle body and intercooler. I've read of a handful of posts of VRSF and AA pipes occasionally popping off at the throttle body. I haven't read anything about ER pipes popping off. Price isn't an issue. I just want the best fitting one. I will not be upgrading my IC.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
07-14-2018, 02:32 PM | #2 | |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
sspade2467.00 |
07-14-2018, 05:59 PM | #3 |
A family of bimmers
2748
Rep 7,742
I too have the vrsf fmic and cp and they have been great. Figment was spot on and had no trouble getting it on the throttle body. I used their clip as it was slightly thicker than oem and fit perfect.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-15-2018, 06:20 AM | #4 |
364
Rep 775
Get ER CP, be happy, move on. Am sure the guys looking to save a few $$ will chime in about _______, yet do a search about ER CPs. Decide for yourself what works and is 'worth it'. (mic drop)
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
MARC20102.00 |
07-15-2018, 07:41 AM | #5 |
1838
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Just installed a VRSF charge pipe to replace a broken OEM unit - no problems with fitment and it took longer to remove the old CP than put the new one on. I like the black crackle finish rather than the polished look of the ER, but their products are very well-engineered (had some on my previous car). I chose VRSF because I'll be changing cars next year and my current one isn't highly tuned. One other thing I like about VRSF's CP is that I bought it as a kit complete with replacement throttle-body o-ring and clip.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-15-2018, 10:08 AM | #6 |
3112
Rep 4,358
i do not know if it's the best fitting or most reliable but here are some others to consider.
i have the cts turbo fmic and ftp charge pipe combo set on my N20. no quality/fit/finish issues...works great, lasts a long time, so far and would buy them again if i had an N55. you can get the ftp N55 combo set(charge+tic) for the cost of the single ER charge pipe. http://www.ctsturbo.com/cart/product...-5043-116.html http://www.ctsturbo.com/cart/product...IT-4939-7.html https://www.ftpmotorsport.com.tw/pro...55-charge-pipe https://www.ftpmotorsport.com.tw/pro...n-packages-1-1 |
07-15-2018, 11:04 PM | #7 |
587
Rep 898
Run FTP. Fitment is great, comes with all orings which is awesome. Have ER on the M2.. was a bit more of a pain to fit. Though also did FMIC at the same time.
FTP on the X3, stock FMIC.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
07-16-2018, 12:45 PM | #8 | |
5559
Rep 5,374
So, it sounds like you've had many CPs. Out of all of those CPs, you find the FTP to be the best? Looking at the build quality and reviews (there aren't many) and disregarding the price, the FTP seems built quite nicely and also comes with an extra o-ring and TB clip.
07-16-2018, 03:27 PM | #9 | |
587
Rep 898
I've done research on VRSF. And from all my research I decided on ER & FTP. I didn't want to go with FTP at the time since they were less known on my M2 ( back in late 2017 ) but since then, I've done more research and went with FTP for the x3. Fitment & finish were quite nice. Though the ER in the black finish does look a bit more stock like due to no badging and is a smooth finish vs the wrinkle powder in case you worry about state ref's.
