07-13-2018, 01:45 PM | #1 |
Rep 26
question about tires
plan to get the 20" wheels setup. But not sure What size tire should i get. Width of the wheels are 9" front, 10.5" back.
Is this setup right? 225/35/20, front 255/30/20, back Or should i go for wider tires to fit the width of the wheels? Btw, i have a H&R sport springs setup. Thanks for Any reply! |
07-13-2018, 02:09 PM | #2 |
#gotboost
517
Rep 861
What are you trying to accomplish? Those tires will be very stretched at those widths...
For reference, I run 245/40/19 up front on an 19x8.5 +35 and 265/35/19 on the rear on a 19x9.5 +40; also on H&R sport EDIT: Also, probably better luck in the wheels and tires section
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
07-13-2018, 03:07 PM | #3 | |
Rep 26
07-13-2018, 06:31 PM | #4 |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
That is big tire...I think you might be pushing the envelope a bit.
07-18-2018, 03:10 PM | #6 |
Rep 26
My friend told me if i go for 245/35 front, 275/30 rear set up, it will mess up the xdrive/transmisson. He told me i should go for 225/35 front and 265/30 rear. Can anyone confirm this is true?
BTW, the rear wheel is 10J, not 10.5J Thx for Any reply! |
07-18-2018, 03:27 PM | #7 |
#gotboost
517
Rep 861
Again, you would have better luck in the wheels and tires section rather than general discussion. As I said above, a 225 is going to be stretched the F out on a 9" width. Google 225 on 9 inch to get an idea. They're your wheels and tires though so whatever you want..
07-29-2018, 03:54 PM | #9 |
8264
Rep 16,111
