BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 2009 328xiT P2096 & P2196
      07-12-2018, 11:56 AM   #1
ihbase
363
Drives: e90, e91, f31, f87
88k miles, manual transmission, fair service history.
Cleared codes and replaced both upstream O2 sensors.
Codes returned.
Wire harnesses for upstream senstors passed test.
Smoke test revealed no vacuum leaks.
Ether around intake gasket revealed no vacuum leaks.
No sign or sound of exhaust leak.
Replaced both downstream O2 sensors.
Codes returned.
Any ideas?
Thanks,
Mike
      07-16-2018, 08:43 AM   #2
simplesilver
Drives: 07 328i sedan automatic
Does your scanner tell you what the codes definition are?
      07-19-2018, 06:43 PM   #3
ihbase
363
Yes, but I do not have them available right now.
Pulled intake because starter was drawing too much current anyhow. Intake was good, no leaks. Replaced starter and reinstalled intake.
Replaced MAP sensor and code has not come back. I did not start with MAP sensor because the code was bank specific (Bank 1) and I would have thought MAP would impact both banks.
Anyhow- after a lot of time and cash, CEL appears to be cleared.
-Mike
      07-22-2018, 06:30 PM   #4
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
2214
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Google says
P2096 OBD-II Trouble Code: Post Catalyst Fuel Trim System Too Lean
P2196 OBD-II Trouble Code: O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
Definitely get your hands on a proper BMW scan tool. I'd recommend either CarlyBMW or INPA with a Bimmergeeks cable.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      07-24-2018, 12:57 PM   #5
ihbase
363
Originally Posted by desertman123 View Post
Google says
You are exactly correct. And that is why (2196- Bank 1 Sensor 1) I discounted the MAP sensor. I would have thought that a bad MAP would not be bank specific.
I was wrong. New MAP seems to have addressed the issue.
-Mike
