Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Whiteline Rear Camber Eccentric Bushings
      07-11-2018, 07:57 PM   #1
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
Is there any value to switching to a poly bushing here? (circled in yellow)
https://www.whiteline.com.au/product...=W63401&sq=844
      07-12-2018, 10:18 AM   #2
FCobra94
Guest
n/a
Drives:
That's not where those go.
Appreciate 2
BSM n54iS2684.50
feuer4275.50
      07-12-2018, 11:34 AM   #3
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
Oh my mistake. Where do they go? And is it worth putting poly in that location?
      07-12-2018, 12:37 PM   #4
feuer
feuer's Avatar
4276
Drives: wife crazy!
You circled lower rear inner. Part linked in front lower inner. Is it worth it? That depends on what are you trying to achieve. I think fro the circle part you need this: https://www.whiteline.com.au/product..._number=W63400 Also these aren't eccentric.
      07-12-2018, 01:20 PM   #5
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I'm trying to minimize deflection in the rear suspension. I think the part you linked (W63400) are the 4 trailing arm bushings, which I've already done.
The part I linked appears, to me anyway, to be 2 x 2-piece bushings, for the same application as this powerflex part https://powerflexusa.com/bmwe81e82e8...-pfr5-415.aspx. You can see in their diagram that this would go at the inner "spring arm" attachment point circled in red.
The diff and subframe bushings are all polyurethane. I've also installed adjustable rear toe, guide and wishbone arms.
So at this point that bushing at the camber adjustment eccentric bolt is the only remaining OEM rubber bushing in the rear, and I'm wondering if it's detrimental to leave a singled mismatched bushing pair in there.
      07-12-2018, 01:45 PM   #6
avocet
252
Drives: 2007 328i 2011 X5d
I think it would absolutely be a benefit. I have those exact w/line bushings waiting for install...
Those and the inner trailing arm are the last OEM rubber left for me.
      07-12-2018, 02:09 PM   #7
feuer
feuer's Avatar
4276
Drives: wife crazy!
It will help with what you want to achieve.
Front inner #10
Rear inner #9
https://www.realoem.com/bmw/enUS/sho...diagId=33_1354
Says lower rear inner
Aslo, have you seen these: http://www.n54tech.com/forums/showthread.php?t=48692
Appreciate 2
      07-12-2018, 02:22 PM   #8
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
Those are very interesting. I have the toe arm lockout kit, I'll consider adding these in the future.
      07-12-2018, 02:37 PM   #9
feuer
feuer's Avatar
4276
Drives: wife crazy!
I use the camber kit as I track and wanted to lock the camber. When you do alignments you set camber first. Toe is easier to adjust and even easier if camber is locked. Unless something is bent...
      07-12-2018, 02:47 PM   #10
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I know you track your car, you passed me several times at Autobahn on Saturday!
If I may ask, what lockout spacer do you use (3MM, 4MM, etc) and what are your corresponding rear alignment angles?
      07-12-2018, 02:52 PM   #11
feuer
feuer's Avatar
4276
Drives: wife crazy!
Me? Definitely not. I'm slow. They were few 1-ers! Which one is yours? Angle is set at -2.5 but not sure on the MM for spacers. I only remember was different MM side to side.
      07-12-2018, 03:35 PM   #12
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I was in the silver 135i. It was my first track day on r-Comps so I wasn't driving very aggressive.
      07-12-2018, 04:07 PM   #13
feuer
feuer's Avatar
4276
Drives: wife crazy!
I was on Hankook RS3 that I bought used recently. They were used on track in 2016. We had 3 sessions so I decided to just wear them out completely. Last year I was on Federal RSRR and this year on Nankang RS-2R, both are few seconds faster than the Hankook RS3's. The white 1-er was moving decently but still on the slow side considering all the work.Only car the impressed my with how fast it goes was the blue Camaro. My friend with the blue 335i ran slicks last year and was scaring me how was can go in turns
      07-12-2018, 04:46 PM   #14
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I've met the owners of the blue camaro a few times there. The ZL1 is no joke and they were on lightly used pirelli slicks.
feuer4275.50
      07-18-2018, 10:40 AM   #15
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I received the lockout shims today. They look solid. If you ever get a chance to look at the ones you have installed I'd be curious what mm shims you are using.
I will probably start with the 2 mm shims as i'm running -2.2 now and i think it maxes at -3
      07-18-2018, 11:12 AM   #16
feuer
feuer's Avatar
4276
Drives: wife crazy!
I asked VT this Saturday and was told 0mm on left and 1mm on right. My camber goes from -2.5 to -2.2 depending if I run the 10mm rear spring pad or not.
      07-19-2018, 09:48 AM   #17
FCobra94
Guest
n/a
Drives:
I think the shims are cool and they look like super high quality/solid pieces, but why not just swap out the upper arm to an adjustable unit instead? With the swap you'll also be getting fresh/stiffer bushings and a MUCH more user friendly method of camber adjustment.
      07-19-2018, 03:42 PM   #18
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
I already have adjustable upper guide and wishbone arms. They are a giant, giant pain in the ass to adjust and tighten. Probably user error.
I bought them mostly for the solid bearings to replace the OEM rubber bushings. In retrospect this was probably a waste, and I should have just replaced the bushings themselves.
      07-19-2018, 03:48 PM   #19
FCobra94
Guest
n/a
Drives:
That's a shame...my Manzo toe arms are a breeze to adjust. Would assume their upper arms would be just as easy to adjust given equal design.
feuer4275.50
      07-19-2018, 04:11 PM   #20
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
The issue with the upper arms is getting a wrench up past the hub and the lack of room to tighten and loosen. SPL arms use a pinch bolt design that’s easier but the price reflects a higher quality of material and engineering.
Appreciate 2
feuer4275.50
      07-21-2018, 08:02 PM   #21
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
So I've decided to hold off on the camber bushings. A bigger issue are the soft OEM rear top shock mount bushings. They are ridiculously soft and compliant. I'll be replacing them with Powerflex Black bushings this week, hopefully this reduces some of the rear end bounciness.
      07-22-2018, 09:31 AM   #22
feuer
feuer's Avatar
4276
Drives: wife crazy!
Many of us on here use Monroe upper shock mounts. Probably just as good as Powerflex but cost lot less and be more comfortable.
