BMW X5
      07-10-2018, 10:43 AM   #1
spike5150
422
Drives: 2020 X5 M50i
G05 Tire Sizes
Looks like rolling diameter is increased by up to 1 inch with the G05. Guess we won't be recycling wheels and tires. Bummer because I really like my winter setup...
- 265/50R19 vs. F15 at 255/50R19 (+0.4" Dia)
- 275/45R20 vs. F15 at 275/40R20 (+1.0" Dia)
- 315/35R21 vs. F15 at 325/30R21 (+1.0" Dia)
- 315/30R22 vs. F15 at 325/30R21 (+0.7" Dia)
Anyone heard any specs on hub diameter for the G05?
      07-10-2018, 11:45 AM   #2
Kief
Kief's Avatar
4433
Drives: '24 iX50; '23 i4 M50
Don't forget the G chassis has 5x112 bolt pattern compared to 5x120
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      07-10-2018, 04:52 PM   #3
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
Originally Posted by CINISI View Post
So Audi wheels may fit depending on the offset.
Yes. Maybe even Macan wheels but what about the center caps
      07-12-2018, 11:42 AM   #4
CoTony83
CoTony83's Avatar
253
Drives: 22'X5Mc
what is going to be the winter tire options for the optional 275/40/21 fronts and 315/35/21 rears?
      07-12-2018, 12:20 PM   #5
Thrumcap
56
Drives: 2019 Audi Q7
Curious about those who get the 20”+ wheels on the X5. Is it just for looks? Where I am the roads are so bad that I usually go through a couple per year due to potholes. Was thinking of downsizing to 19” for some more sidewall and durability.
      07-12-2018, 12:32 PM   #6
spike5150
422
Ability to run performance tires in the summer, and looks play a factor for me also. Potholes not too bad where I am. If they were it would be a factor.
      07-12-2018, 12:37 PM   #7
Influence
396
Drives: 2020 X3M, 2016 X5 35i
Say it isn't so . . . does BMW do this on purpose to us so that we can't use our winter and or summer aftermarket sets from one generation to the next?
My set of 22" 599M replicas would have looked really good on a new G05. Darn it.
      07-12-2018, 01:40 PM   #8
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Changing bolt pattern really sucks. F15ers would certainly be interested buying those.
      07-12-2018, 01:51 PM   #9
ptm1nh
ptm1nh's Avatar
Vietnam
202
Drives: Blue Cars
True. I am planning to upgrade my 21" to 22" next year and looks like my plan is screwed now, unless bolt pattern adapter is such a thing...
      07-15-2018, 11:54 AM   #10
TXLFC
Drives: Jeep GC
Does anyone else find it odd that the wheel specs in the ordering guide suggest the G05 wheels are narrower compared to F15?
For example:
F15 469M 20" wheels are 20x10 front (275 tire) and 20x11 rear (315 tire)
G05 741M 21" wheels are 21x9.5 front (275 tire) and 21x10 rear (315 tire)
G05 742M 22" wheels are 22x9.5 front (275 tire) and 22x10.5 rear (315 tire)
      07-15-2018, 03:00 PM   #11
RDG80M3X
RDG80M3X's Avatar
No_Country
612
Drives: '23 G80X
For example:
It is definitely an odd choice considering the fact that the G05 is longer, wider AND taller than the outgoing F15. Given the increase in size and stature of the G05, you would've thought that they would go with something more aggressive (IE: 21x11F and 21x12R) OR at least maintain the same widths. I've also noticed this on the new 8 series as well - the wheel fitment is quite tame for the standard car. Car looks really disproportionate/top heavy with the sunken in wheels. Lets hope that this isn't becoming a trend as I've always found OEM BMW wheel fitments quite attractive in terms of looks/proportions which really complement the overall design language of their cars.
      07-18-2018, 12:49 PM   #12
MysticBlue
369
Drives: '20 M5C, '09 M3 DCT Coupe
Really!!!??????
Why?
I have Pirelli winter tires on a set of 469's. Works great and I planned on using them on my 2020 M50i.
Again, why can't they just be the same?
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      07-18-2018, 09:03 PM   #13
X54TH
Member
X54TH's Avatar
898
Drives: 2019 X5 40i M Sport
Damn! I guess I'll put up the F15's Winters for sale. By the time the G05 comes we'll be in Winter and snow. That's another added expense. This G05 is starting to add up.
      07-19-2018, 06:23 PM   #14
X54TH
Member
X54TH's Avatar
898
So I'm thinking of using the F15's Pirelli ice and Snow RFT's 315/35/20 and 275/40/20. Are there any current BMW rims that have the right bolt pattern and offset?
      08-29-2018, 12:24 PM   #15
like2short
139
Drives: E93 m3
Mercedes is 5 x 112 with same bore as new BMWs at 66.6mm
Once we know the offsets for the X5, look for a Mercedes off a GL/GLS ML/GLE or maybe a heavy S-Class.
The GL/GLS is high negative offsets like -56 to -60
ML/GLE is around mid 50s for negative offset
S Class is lower.
New Audi Q7 is also now 5x112 and same bore with offsets around -30 ish.
      10-14-2018, 04:03 PM   #16
rexus300
154
Drives: car
Yeah thats what I was thinking! Hartmann wheels make the 5x112 bolts patter wheels that are great for winter time. I use them on my Audi sedans for winter time.
      10-21-2018, 12:03 PM   #17
StefLach
Drives: X5
Mine is getting delivered in November with 22" Summer Tires. Getting the 21" 741M Style Wheels to put on Winter Tires, but can't find them in the 315/35 R21 size for the rear. Anyone know where to possibly purchase them to match the front 275/40 R21?
      10-21-2018, 12:04 PM   #18
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
If I want to order a set of winter wheels and tires in 19 or 20", what size and offset do i need?
      10-21-2018, 12:29 PM   #19
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
S Class is lower.
Use caution for wheels that are Mercedes fit as the OEM lugs are ball seat and shank diameter on some is 12mm instead of 14mm. BMW is M14, 60° cone seat.
      10-22-2018, 05:17 AM   #20
Kakalika
Kakalika's Avatar
101
Drives: 2014 X5 35d M Sport
You could always use adapters, I think..
No Affiliation.
https://www.ebay.com/itm/5x112-to-5x...-/171943677837
I'm not sure if we are allowed to post ebay links. Moderator, please delete if this is forbidden.
RUN FLAT TIRES? NEIN DANKE!
      10-22-2018, 05:30 AM   #21
Kakalika
Kakalika's Avatar
101
Or have a reputable shop CNC a new bolt pattern.
These guys in Georgia can do it, and apparently they can resize the hubs to the G05 as well. I don't know how the hell they would do that.
      10-22-2018, 05:38 AM   #22
Kakalika
Kakalika's Avatar
101
I have the old school BBS Style 101 wheels with the lip. I love these wheels with a passion. I had them bored out to fit my E70. I would love the bolt pattern changed to fit the G05. (If I ever buy one!!!!) These wheels use the large center caps that cover the lugs, so any imperfections in the machining (If any) would be covered.
xbimmers
