07-09-2018, 06:00 PM | #1 |
Joint Chiefs of Staff
24095
Rep 190,633
WAGNERTUNING Radiator Kit BMW F-Series B58 Engine
The 3.0 Liter B58B30M0 turbo engine of the specified BMW models is equipped with an indirect charge-air cooling circuit. So the cooling of the charged air is not realized by the ambient air as cooling medium (as usual), but made with its own cooling water circuit. A reduction of the temperature of the cooling water is directly equated with an improved cooling performance of the charged air. This is exactly where the advantages of the WAGNERTUNING upgrade radiator comes into play. The new developed competition racing core of the WAGNERTUNING high performance radiator increase the radiator volume of the OEM water cooler by a total of 117 %. The calculated ratio between the inner and outer cooling surface generates a maximum heat transfer and allows at the same time enough air flow for the surrounding components (for example the engine radiator) for its own heat exchange. Furthermore, using an increased amount of cooling water, the entire system thermics can be kept at a lower level over a longer period of time. All WAGNERTUNING radiators are equipped with a heat-conductive anti corrosion coating to ensure a lasting cooling effect. The plug & play installation of the system is simple and easy to perform (an installation instruction is included as well). Dimensions OEM radiator: 576 mm x 495 mm x 27 mm V = 7,70 Liter A = 2851 cm² Dimensions WT radiator: 524 mm x 468 mm x 68 mm V = 16,70 Liter A = 2454 cm² Competition - Radiator - Kit for the BMW B58 Engine (M140i, M240i, 340i, 440i)
THIS ITEM CAN ONLY BE USED IN A COMPETITION RACING VEHICLE THAT IS NOT DRIVEN ON PUBLIC ROADS, UNDER CALIFORNIA STATE LAW IT IS NOT LEGAL FOR USE IN ANY OTHER MOTOR VEHICLE!
07-11-2018, 07:37 AM | #3 |
716
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
To ensure I get it right - this is an upgraded radiator specifically for the charge cooling system.
07-11-2018, 03:59 PM | #4 |
24095
Rep 190,633
I will check with Wagner Tuning and let you know once they reply
07-17-2018, 12:28 PM | #5 |
3487
Rep 9,709
Is there a series of typo's in the specifications?
I'm told the engine coolant capacity of the B58 is around 7 litres. You list 7.7 litres for the intercooler coolant, which doesn't make sense, as there would be significantly less in this circuit. Then the WT one holds nearly 17 litres? I'm pretty sure an at least 10kg coolant increase is not going to be a good performance modification, especially as there isn't a documented issue with uncontrollably high intake temps. (My track day logs show pretty consistent AIT lap after lap) |
07-17-2018, 02:42 PM | #6 | |
Car Geek
3612
Rep 3,579
07-17-2018, 04:58 PM | #7 | |
3487
Rep 9,709
If only it worked like that huh! I'm talking thickness of core. Think I'd need empirical data before I was convinced a thicker radiator was actually an upgrade. |
