Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Need to replace a failed CIC, what do I need to look for??
      07-09-2018, 08:07 AM   #1
hotbox
Member
hotbox's Avatar
Drives: FBO 335is
Hi all,
My CIC has died, it re-boots every 30 seconds, so it needs to be replaced. Does it matter what options are on the donor car to be used if it will just be re-coded anyways? Should I just buy something from Ebay for this or would that just be a bad idea?
Thanks!
      07-09-2018, 08:43 AM   #2
opjose
opjose's Avatar
242
Drives: 335xi
Originally Posted by hotbox View Post
Hi all,
Thanks!
You may want to pull the hard drive out and see if it stops rebooting.
If it does you do not need a new CIC, but you will need a new drive.
      07-09-2018, 03:28 PM   #3
hotbox
Member
hotbox's Avatar
Drives: FBO 335is
Already went down that rabbit hole and swapped out hard drives, at least now I have a SSD ready to go...
Besides being a CIC from a E9X, do I have to look for something specific?
      07-09-2018, 04:15 PM   #4
opjose
opjose's Avatar
242
Drives: 335xi
If you've obtained an image of the old CIC, you'll do fine.
I suggest reading out the configuration of your old CIC, installing the replacement CIC and coding it with the config you read out, then swapping in the SSD drive.
The replacement CIC will pick up the FSC codes from the SSD drive and you should be all set.
      07-10-2018, 08:03 AM   #5
hotbox
Member
hotbox's Avatar
Drives: FBO 335is
How would I go about doing this, with the use of FSTool or something else? I assume that this would then allow the navigation and combox to all work with the new CIC, but does it matter when the replacement CIC was manufactured?
Thanks for the information!
      07-10-2018, 09:54 AM   #6
opjose
opjose's Avatar
242
Drives: 335xi
Use INPA to read out the coding of your current CIC.
Then apply that to your replacement unit.
Hopefully the replacement unit will have a close revision level and will work without updating.
If not it may have to be updated.
      07-11-2018, 03:06 PM   #7
hotbox
Member
hotbox's Avatar
Drives: FBO 335is
OK great, thanks! Replacement CIC has been ordered
      09-02-2018, 08:35 AM   #8
Gee-Dog
11
Drives: E92 335i
I may need to do this in the near future, so I'm interested in how you get on replacing your CIC. Have you done it yet, and what was the process to get the replacement unit working?
      04-20-2019, 04:46 PM   #9
CPhillips1981
Drives: 2009 335xi, 2014 x3 35i
Any updates?
      05-26-2019, 12:27 PM   #10
Bufalo
124
Drives: 2009 328i
2017 BMW X3 35i  [0.00]
2009 BMW 328i  [0.00]
So if you have a car with an early CIC version, and you buy a used CIC head unit from a later build car, what would need to be changed in coding to use it? I'm looking for a fairly do it yourself way to move from my 09, error prone firmware cic to something newer that can take map updates and a combo, and finding a way to update my firmware isn't especially homebrew friendly so far.
      05-26-2019, 01:40 PM   #11
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I can just update your current CIC.
      05-26-2019, 03:51 PM   #12
Bufalo
124
Drives: 2009 328i
That'd be best, and you're actually local.
      06-09-2019, 12:56 AM   #13
BestBet80
Drives: M3 (E92) Comp, M2 (Comp), E30
CIC Red Flicker?
Hi - has anyone seen this before? Not quite the ‘Red Screen of Death’ but could it be the beginning of the end? I hope not because the upgrade was only done last week! Thanks in advance for any help/genius that can be shared.
      06-09-2019, 10:37 AM   #14
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
So I ordered a replacement unit for my E70 that came with CIC from the factory. My car is a 2010 3.0si but I bought one from a 2013 X5 //M. It booted up fine but I had no audio output and none of my cameras worked.
I had a backed up CIC code file from the original unit, so i flashed that over to get audio and other functions working. But now navigation is greyed out. I see a lot of options to enable it with a cic upgrade/retrofit, but with it from the factory do I need all of that or is there a coding option? I also find it weird that it worked upon initial install, but after flashing the coding over from my original unit it doesn't work anymore.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
Tags
cic
